windshield smudges. help!
  • #46
    Re: windshield smudges. help!
    +10000 on the UC.. that stuff is MEAN. Only one time did i need to go to the glass water spot remover over the UC and it was because the lady was parking uder a leaking water pipe in her building and was etching in for over a year.
    UC, on a foam pad IMO works great. On a microfiber pad i find it dries too quickly.. Work it in good, then clean really well. Add the QD and presto u should be good to go.
    Chances are its not defective glass.. its gotta be some kind of residue thats embedded pretty good.
    • #47
      Where would be a good place to find foam pads? Walmart, advance auto parts, etc...none of them around me have any. They are all the microfiber kind.
      • #48
        Hard to say... online usually.
        • #49
          After applying ultimate compound do I use a Terry towel or microfiber towel to wipe it dry?
          Also, how much ultimate compound do I apply to the foam pad? Small medium or large amount? Do I apply it in swirls?
          • #50
            A MF would probably remove best.
            You can apply it with foam or terry cloth. I guess a medium amount.. I mean you need to be able to wipe it across a small section, then work it in some.
            • #51
              It's 50 in WI today so I will try it. Do you think it's a good idea that I apply it when it has been in the shade? I have it parked outside in the sun for a while today.
              • #52
                Does the glass even feel warm? I doubt it matters at 50.
                • #53
                  Sort of. I was just wondering how sensitive the UC is to he window at certain temps.
                  • #54
                    Probaby better a tad warm.
                    • #55
                      Its fine to do it directly in the sun?
                      • #56
                        Yeah, the sun doesnt matter.
                        It is the surface temp.
                        • #57
                          I also have a '05 Toyota Highlander with polished aluminum rims. Is UC safe to use on them?
                          • #58
                            How did the glass turn out?
                            Yeah, it would be safe, acts kind of like a metal polish.
                            • #59
                              So far it looks like it worked, but until it rains I really can't wait.
                              On the downside it really didn't help on my wife's rims. Check out my other thread.....
                              • #60
                                Well, hopefully a start...
