Jason Rose will be conducting a series of seminars at Mobile Tech Expo in Kissimmee, FL on January 19th - 22nd, 2012. If you're a professional detailer, or just interested in advancing your skill set, these seminars are a great way to enhance your capabilities.
Jason's topics will include:
DA Microfiber Correction System - Guaranteed swirl-free paint defect
removal with a D.A. polisher...at its best. Does your rotary polishing have
you going in circles? Or does your lack of knowledge and experience with
rotary polishing prevent you from getting defects removed without fear of further
damage? Want to make more money machine polishing paint? Learn
how easy it is to get fast customer pleasing results on paint. Perhaps you have
tried this new revolutionary polishing system, and want to learn more? This
seminar explains what this remarkable new approach is, advantages over
rotary polishing, and how you can experience lower labor/material costs with
more profit per car. Bonus - learn about the tremendous versatility of this
exciting new system and its many uses beyond just polishing paint.
The Power of 3000 Grit! - That's right, you read it correctly...the POWER of
3000 grit?! Isn't 3000 grit sand paper considered mellow? The Meguiar's
Unigrit 3000 Finishing Disc is different. This amazing new approach represents
the future of removing severe paint defects.. You can continue to hammer
them out with more aggressive methods that are risky or too invasive on
paint (like rotary with a heavy cut compound and wool pad)...or...you can
have a new approach with complete control, and lower risk, removing severe
defects fast & easy while leaving more paint on the car. This new approach
makes it possible to go after severe defects with an all DA process or less
aggressive rotary steps. Come and check out this seminar to see if this new
approach will fit into your paint defect removal processes.
Headlight Restoration for Big-Time Additional Revenue - Headlight
restoration is an easy up-sell with very little additional time and effort. It's the
fastest growing new revenue segment for detailers right now. Learn this easy
to use system. The process will be explained start to finish. You will walk
out of this seminar knowing what the steps are...and how much more additional
money you could be making in your business.
Paint Defect Removal Rotary Polishing Technique - Rotary polishing
techniques are explained and analyzed. What are the 5 rotary machine
polishing variables? How does each variable contribute to the over all
polishing result? Are swirls a challenge for you? Having trouble adjusting
between hard and soft paint? From a global perspective, how do techniques
differ around the world? Which technique should you be using?
This seminar is primarily targeted towards experienced rotary users that
want more understanding and versatility with a desired technique.
However, for someone new to rotary polishing, this seminar will help to
understand concepts and variables before learning which technique is
best for you to master.
More information on times and locations are available at the Mobile Tech Expo website.
