I would like to know your opinions. How much more aggressive is the mild clay over the smooth clay?
Smooth Clay Vs. Mild Clay
Re: Smooth Clay Vs. Mild Clay
There is a noticeable difference in aggressiveness between the consumer clay and the C2000 Pro Mild blue clay. Heavier contamination will be removed faster, as will over spray, etc. Usage is otherwise identical between the two. On extremely delicate paint some light hazing may occur with the C2000, but this is quite rare. If it does happen, you'll need to use a light paint cleaner or maybe even just a cleaner wax to remove the haze. If you intend to machine polish after claying anyway, then this is a moot point.
For the record, the C2100 Pro Aggressive red clay is much more aggressive still. It is very likely that this clay will haze paint, even if the paint isn't terribly delicate. It really should only be used in cases of extreme contamination and when machine polishing is planned as part of the process.Michael Stoops
I believe the Meguiar's clay is very similar to, if not the same as, other mild blue clay available on the market, such as 3M, Clay Magic, etc. From what I read, clay formula is patented and manufacturers get the licence to use the formula.
While Meguiar's white clay is milder than blue clay than red clay,
The review on blue mild clay of different brands is generally positive, so I guess the 2 clays are still safe as long as you use them in a well lubricated way.Dennis
Nissan Fuga | 日產 風雅 | 日産 フーガ
