Considering purchase if the microfiber system. Need the pro's and cons of usage and results. Thanks.
Microfiber System
Re: Microfiber System
Here's an article on how to use the system:
Using Meguiar's D/A Microfiber Correction System2011 Car Crazy Showcase SEMA Team
Originally posted by outlander View PostConsidering purchase if the microfiber system. Need the pro's and cons of usage and results. Thanks.
1. Worked noticeably better on my hard paint than the regular DA/foam pad/Ultimate Compound regimen.
2. The pink stuff (the one that smell's like cinnamon, I actually don't know what it's called) application with the microfiber pad is very similar to the traditional way, so you don't have to learn come complicated new technique. Mainly just use more pressure and clean the pad often.
3. The blue stuff (smells like blueberries) is the finishing polish or wax and is easier to apply and use than Ultimate Polish. Literally just wipes right off with a single swipe, absolutely bugging necessary, or even advised.
The obvious con would be you have to buy more stuff. But that's part of enjoying life as a Car Crazy guy, keeps you off the streets and out of the bars. Which to me is really more of a pro than a con.
If you're a professional detailer and have any pride in what you do, you have to know about the DA microfiber correction technique.
Originally posted by Joe Dragon View PostThere are also a few long threads on the pros and cons if you do a search.
