Can I use the headlight restoration kit on the soft windows? I have 2 Jeeps and one the windows are pretty bad.
Jeep top
Re: Jeep top
The wool pad from the headlight restoration kit, and the PlastX as well, can certainly be used on plastic windows like those found on Jeep soft tops and many convertible tops. If that previous owner put some fairly deep scratches in the plastic with an ice scraper those might not come out with this process, or any other process for that matter. Since you do need to put a bit of pressure against the surface being corrected, it's a good idea to have a helper hold something solid against the inside of the plastic window to give it some support. Wrapping an appropriately sized piece of plywood in a soft towel works well, or a big coffee table art book similarly wrapped to protect the inside of the plastic.Michael Stoops
