I am having problems with microfiber cutting pads. The results I am getting are great, but the pads seem to fail very quickly. I just finished polishing a Infiniti G35 and had another 2 pads fail. The adhesive that holds the microfiber to the foam pad fails and I am left with what you see in the pics. These pads have been used approximately 2-3 times. I was using a Flex Dual Action buffer on speeds 3-5. I'm assuming that the heat generated during compounding/polishing is causing the adhesive to fail since I never have this problem with the finishing pads.
Any advice on how to avoid this? Is this just the normal amount of use you get with these pads? Thanks
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
