DA G110V2/MF finishing pads
  • DA G110V2/MF finishing pads
    I would like to apply Meg. Ultimate liquid wax or M26 liquid wax using my DA G110V2 with the MF finishing pad. If you could advice me if this is a good approach and if any one done it in the past. The question I had is that: MF finishing pad has a little cutting power; if i used to apply ultimate or M26 liquid wax using MF finishing pad will do any cut to the paint or MF finishing pad is a product dependent - and what speed you recommend. Thanks to all.
    Re: DA G110V2/MF finishing pads
    Sure, apply the wax by machine is good, and yes, use a finishing pad. The Ult. Wax went on well for me by machine.
    You wont get any cutting/cleaning ability with the wax and finishing pad.
    The speed on the V2 will be around 2-3.
      If you're using the MF finishing discs, I think you'd get some mechanical cutting ability because of the MF fibers. Since you're using a pure was such as Ultimate Liquid Wax or M26, I would highly suggest using the W9207 foam finishing pad. You want your applicator to be as soft as possible so that you don't introduce any marring or micro-scratches.
        Whoops.. missed the MF...
