Re: The Power of 3000 Grit
In theory, yes, but you aren't using a sanding disc in quite the same way you use a compound and pad. Mostly the smaller size is used to work in a smaller area, but it's also true that you generally don't sand for as long a time period when using the 3" discs due to the aggressiveness. Risk of strike through is still minimal if you're simply paying attention to what you're doing, take your time, do multiple attempts rather than just try to blast through it, etc. Of course, with time and usage comes experience so you get a feel for what's going on as you get better at it. But for beginners, the best thing you can do is take your time, do multiple attempts to give you a feel for the speed of cut, etc and overall - PAY ATTENTION!!!
Originally posted by Old Bear
View Post
