Polishing Compound and clay bar process
Results 1 to 9 of 9
Thread: Polishing Compound and clay bar process
    Jun 2012
    Olympia Washington
    48
    8
    Is the Clear Coat Polishing Compound safe to use on paint with no clear coat?
    If I am able to safety use this PC, shhould I use the clay bar before or after the PC?
    39
    19,107
    237
    Re: Polishing Compound and clay bar process
    Yes, Polishing Compound would be safe for clear coat, or single stage paint.
    You would wash, then clay, then polish, then wax.
    Jun 2012
    Olympia Washington
    48
    8
    Sorry I was not clear. This is a 1997 Miata and I suspect it does not have a clear coat. Does that make a difference in using PC.
    Jun 2012
    Olympia Washington
    48
    8
    If I understand the process I should use a terry cloth applicator pad to put on the PC. How much pressure should I put on the pad when I put on the PC. Pressure equal to or less that what is used for typical polish?
    What should I use to remove the PC.?
    Aug 2004
    Glendale, AZ
    35
    2,962
    51
    The technique should be the same but the products can be different. Instead of using UC/UP, it hs been said that M83 and M80 are better products for single stage paints.
    Use a microfiber towel to remove any type of product. That will be your safest bet.
    Jun 2012
    Olympia Washington
    48
    8
    Quote Originally Posted by Marc08EX View Post
    What do the acromyns M83 and M80 stand for.
    Aug 2004
    Glendale, AZ
    35
    2,962
    51
    Jun 2012
    Olympia Washington
    48
    8
    So if I understand correctly these should be used instead of the rubbing compound and be applied prior to the clay bar procedure.
    But then it is polish so maybe that indicates it should be used after the clay bar process and following the application of the M83 or M80 the wax should be applied.
    Aug 2004
    Glendale, AZ
    35
    2,962
    51
    You can follow the advice in your first thread here: http://www.meguiarsonline.com/forums...ht=#post508079
    Just substitute M83 for UC and M80 for UP when your paint is single stage. These products are used after claying the entire car.
  1. Paint Chipping During Polishing Process ?!!!
    By khaled_topcare in forum Detailing 101
    Last Post: May 10th, 2012, 03:40 PM
  2. Rubbing Compound(RC) & Polishing Compound(PC)
    By Vios 5300 in forum Detailing 101
    Last Post: Jul 8th, 2011, 08:16 AM
  3. Rubbing Compound & Polishing Compound
    By Michael Stoops in forum Meguiar's Consumer Line Products
    Last Post: May 12th, 2011, 11:48 AM
  4. What is your process after compounding and polishing?
    By johnnys in forum Detailing 101
    Last Post: Mar 13th, 2009, 08:17 AM
  5. Gel Coat polishing process
    By Hemin8r in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: May 16th, 2008, 07:37 AM
