Cutting Pad vs Polishing Pad & DA
Results 1 to 4 of 4
Thread: Cutting Pad vs Polishing Pad & DA
    Registered Member Question Boy's Avatar
    Dec 2004
    15
    When using the DA will I get a little more "cutting" action using DACP #83 on a red Cutting pad versus the yellow Polishing Pad??
    Des Moines, Iowa
    39
    5,605
    76
    Check this post out...
    http://meguiarsonline.com/forums/sho...PC+cutting+pad
    Meguiars suggests not using it with a PC but check the post out.
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Feb 2004
    Southeast Nebraska
    916
    27
    I've used the maroon cutting pad and DACP several times for deeper scratches and swirls. I followed up with DACP and a polishing pad. This was on my black Hemi. No problems.
    Tom
    Registered Member Lt1Corvette's Avatar
    Aug 2004
    643
    21
    I to have used the cutting pad with the da. Tried it a while back on my sisters car. I had good results but as eveyone has said, using it is taking a step backwards. After I went over her entire car, the paint did not look good. However following with 83 on a 8006 pad brought the finish back and the deeper scratches I was going after were gone. It can work well you just need to be cautious.
  1. 2.0 Foam Cutting Pad & D151
    By BBoe in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Oct 28th, 2008, 08:08 AM
  2. Cutting Pad
    By jezroj in forum Machines - The Dual Action Polisher
    Last Post: Aug 24th, 2008, 02:30 PM
  3. #83 with a Light Cutting or Polishing Pad???
    By GTBrad in forum Detailing 101
    Last Post: Aug 7th, 2006, 07:52 PM
  4. Cutting Pad V Wool Pad
    By Tanat198 in forum Detailing 101
    Last Post: Mar 7th, 2006, 08:40 PM
  5. First time using the cutting&polishing pad
    Last Post: Dec 21st, 2004, 06:04 AM
