Re: White Wax
Do not give up the clay in favor of White Wax. White Wax is a cleaner wax formulated for lighter colored cars because they tend to need more defect removal and less polishing oils. To decide on which wax to use, if you want to choose between Black Wax or White Wax, look at the car in the sun. If there are many light to medium scratches in the CC then White Wax would be best, if there are little, or many very fine scratches, then likely Black Wax would be best. If your son's 350Z has a lot of scratches, use White Wax, if little or barely noticeable, go with Black Wax. Regarding pin striping, I cannot say for sure if it would be safe.
If you have no visible swirls, then use Black wax if you want to check out one of these new waxes, however NXT 2.0 will likely have longer lasting protection.
Originally posted by Zcar
View Post
