Black Wax
  • #91
    Re: Black Wax
    ^ I believe Walmart is in Canada as well. If so, I would check there.
    2012 Acura CBP TL SH-AWD Tech
    • #92
      Re: Black Wax
      Yes there are Walmarts here but no Black Wax.
      • #93
        Re: Black Wax
        ^ Quite possible they ran out of stock. Should ask them if they indeed do stock the Black Wax and if so, when they expect to replenish. Or even possible ask if they can locate another Walmart near by that does have it in stock. I don't know if Sears and Advanced Auto has presence in Canada but they stock Meg's as well.... at least the ones in my area.
        • #94
          Re: Black Wax
          what do you think if we coat #26 yellow wax over BW.... is #26 a better version of GC or vice versa?
          • #95
            Re: Black Wax
            Either would work fine.
            I dont know about major differences between them. Probably more of a price issue....
            • #96
              Re: Black Wax
              what do u think if i clay my car first then use ultimate polish as it has more properties to remove minor imperfections and then use black wax and after 12 hours use UPW or #26 (recommend)??? and the reason why i am planning to apply UP is because i will be using my hands to do all this
              • #97
                Re: Black Wax
                I don't think you will get much defect removal out of Ult. Polish... so probably a waste on that front, unless very minor or very soft paint.
                • #98
                  Re: Black Wax
                  What is the cleaning power of black wax relative to the other cleaner waxes? I've become a huge fan of the daily driver detail, using color x (awesome product!) and following with a finishing wax. But now I want a milder cleaner wax for more regular use, should I step down to black wax or even further (a12, m20??).
                  • #99
                    Re: Black Wax
                    Black Wax is pretty mild, similar to A12.
                    • Re: Black Wax
                      Does the black wax leave small crystal like pieces on the hood?
                      I believe the bigger pieces on my photo are dush but there are smaller pieces after I waxed with it that don't seem to go away.
                      • Re: Black Wax
                        It's not just the metallic flake in the paint is it?
                        Another common thing (especially for hoods) is there are lots of tiny rock chips in the paint, and often a polish or wax can become stuck in there if you don't wipe it off properly...
                        • Re: Black Wax
                          I believe it is the metallic flake.
                          You might be right about getting stuck in the paint, what did I do wrong?
                          • Re: Black Wax
                            He means that you're paint (maybe) is supposed to have metallic flake in it. What make, model, year is the car? what color is the paint called?
                            2018 Acura RLX Tech - Majestic Black Pearl
                            • Re: Black Wax
                              Yeah, I meant maybe it's metallic flake within your paint that's supposed to be there. Maybe you just didn't notice it before because the paint was dirty / dull.
                              If it's wax stuck in the rock chips, you just didn't buff it off properly, that's all. Chances are its dried up in there now, so a QD or your next wash should remove it.
                              • Re: Black Wax
                                Metallic flakes on the paint. Don't try to do any further removal of there, you will end up instilling those beloved swirls or light micro-scratches on your paint.
