M100 Pro Speed Compound
Page 1 of 6 123456 LastLast
Results 1 to 10 of 55
Thread: M100 Pro Speed Compound
    21,405
    1140
    Product Attributes:
    • Fast cutting compound with advanced technology
    • Quick removal of 1200 grit and finer sanding marks for easier polishing
    • Removes deep scratches, acid rain or severe swirls/holograms
    • Works great on fresh & cured paints
    Size:
    32 ounce
    Part Number: M10032
    US MSRP:
    $24.99
    Part Number: M10001
    US MSRP:
    $66.00
    M100 Pro Speed Compound is designed to be an economical, fast cutting compound for use in body shop environments with a wool pad on a rotary buffer. It offers fast cutting with minimal swirl when used with this tool/pad combo, at a very attractive price.
    Nov 2009
    Stang Island, NY
    791
    19
    Meguiars M100 Pro Speed Cut is a fast cutting compound with advanced technology. It cuts fast and easy with zero hazing or swirling. Use Meguiars M100 with your favorite microfiber pads for super-fast cutting results that polish out to a high gloss finish. Meguiar's M100 Pro Speed Compound is the right choice for anyone looking to quickly eliminate or reduce moderate to heavy deep scratches, acid rain or severe swirls/holograms. Meguiars Speed Compound is the right choice for any Pro or Weekend Warrior Detailer looking for an impressive solution for all of your compounding needs.
    So it's not designed for a DA or MF pads? Confused?? 101 would be more applicable for a DA and MF/Foam pads?
    21,405
    1140
    Re: M100 Pro Speed Compound
    No, it is NOT designed for use with a DA and microfiber pads. That information posted elsewhere is incorrect and in the process of being changed at our request. That said, we know that people are going to experiment with it on a DA with all kinds of pads, just as they did with M105 and M101. Fine by us, really.
    But even M101 wasn't designed for use with a DA and MF pads - it was specifically designed for the European aftermarket paint industry where foam pads on rotary buffers are the norm (they almost never use wool pads) and the aftermarket paint is very different than it is here in the US. We created M101 to meet the demands, requirements and workflow of that very specific market segment. But some guys here in the US started re-porting it (re importing, as it were) back to the US and using it with their microfiber pads. They may be getting a lot of dust, but they're also getting really fast cut and a very nice finish, so to them it's more than worth it. And we got enough feedback and demand for it here in the US that we just released it for domestic sale.
    But back to the subject at hand - M100. Again, a specific target market with this product: the mid-tier body shop user who is looking for a cost effective but highly efficient way to quickly remove sanding marks with a wool pad and rotary buffer. In that segment there is a very popular product that we directly targeted with M100. It's from a company that is popular in the body shop world but almost never discussed in detailing circles, and not even sold through your typical online detailing supply shops like ADS, AG, etc. M100 will remove sanding marks faster than this competitor, and leave a nicer finish in the process. Win-win.
    So does that mean you can NOT use this with a DA and microfiber of foam pads? No, it doesn't mean that. We're always open to experimentation. In some cases it will probably do an outstanding job when used that way, and for some people it may even be seen as "the next big thing". We didn't expect that with M101, but there it is. Just keep in mind that if you try it in a way other than it was designed to be used and it fails to meet your expectations, at least you'll understand why.
    Nov 2009
    Stang Island, NY
    791
    19
    Thanx for the clarification Mike
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,895
    67
    It makes perfect sense to give body shops economical, fast and effective way of deep defect removal.
    Now they all can choose between M86, M100, M101 or M105, and so can we. Everybody should be happy.
    Meguiars Indonesia Admin
    May 2011
    Jakarta, Indonesia
    136
    12
    Hi Mike,
    So it's not SMAT then ? and the finish might not be as good as M105 ? Thanks...
    Very Interesting product to try.. Thanks Meguiars
    Oct 2012
    Twin Cities, MN
    78
    9
    For the price, I know I'm getting it! Mike, was this the mystery item when the 2013 products were unveiled? We're all happy soon meant now and not next year!
    CCH Auto Appearance, LLC C. Charles Hahn's Avatar
    Dec 2012
    Lansing, MI
    85
    9
    So basically M100 sounds like an updated/more aggressive M95?
    I suspect this was formulated to target Wizard's Mystic Cut, but I won't ask for or expect confirmation of that.... just thinking out loud.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    Brian's Custom Detailing
    May 2010
    Dallas, TX
    111
    Someone send me some so I can test this stuff out.
    Where detail matters.
    www.brianscustomdetailing.com
    Oct 2012
    Twin Cities, MN
    78
    9
    I never actually heard of Wizard's products until moving to MN a few months back. I'm pretty sure M100 is directly targeted at another "M" product lol.
  1. Meg's M100 Pro Speed Cut
    By Meticulous-Detail in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: Dec 5th, 2012, 08:24 AM
  2. Speed Cut (95) X Ultra-Cut Compound (105)
    By celso oliveira in forum Introduce Yourself - New Members
    Last Post: Apr 10th, 2012, 06:10 AM
  3. M95 Speed Cut Compound - New
    By Mike Phillips in forum Meguiar's 2008 New Products
    Last Post: Jan 13th, 2009, 11:18 AM
  4. M95 Speed-Cut Compound Kit - New
    Last Post: Dec 13th, 2007, 01:36 PM
  5. what pad and speed to use with rubbing compound?
    By dc11r in forum Machines - The Dual Action Polisher
    Last Post: Sep 17th, 2005, 06:24 AM
