how to properly apply #66 quick detailer?
  • how to properly apply #66 quick detailer?
    im just beginning to use aio's and i wanted to know how to properly apply #66 using a rotary polisher?
    what speed? which pad? is it a wipe off? please give as much info as possible
    thanks in advance
    Re: how to properly apply #66 quick detailer?
    #66 is a really easy product to use. I usually apply with a DA polisher, yellow polish pad, speed 4-5. It behaves a lot like a wax, you can do the whole car before wiping it off if you want. I've never applied it with a rotary polisher. I really like #66 for doing just what its called, "Quick details". Its not going to provide any major correction, but its a great product to use on a well maintained vehicle.
    Dr. Detail: I am the detail genius from the movie "Shine."
    Guard: And your name is...?
    Dr. Detail: Uhh... Shiney McShine.
      thanks, wish i had a da polisher, ive only got one at work so here at home i can only work with what i got
      when applied am i supposed to let it haze? or do i polish until its basically gone, like a polish?
        Since M66 has cutting/cleaning ability, your technique, machine, pad, and speed choices will depend on how much cut you need and how workable the paint is.
        Though there isn't a single, fixed answer to your question, here are ballpark suggestions from the thread: Product, Pad & Speed Recommendations for Rotary Buffing
        In use, it acts much like other mild cutting cleaners and polishes. So work it down to a very thin, almost invisible, but still wet film (don't dry buff).
        Unlike a cleaner or polish, which should be wiped immediately while still wet, it's a wax, so let it dry (it'll dry fast if you worked it thin enough) before wiping it off.
        pc
          ^^ Nice reply.
          Good to see you back here pc
            thanks alot, nice reply indeed, ill try it out this week and let you know how ive done
