taking the paint off?
Results 1 to 8 of 8
Thread: taking the paint off?
    Registered Member andy86i's Avatar
    Mar 2013
    United Kingdom
    47
    7
    okay I've heard some horror stories of what can happen when a machine buffer gets into the hands of someone new at this (ie: me) and heard it can go through paint in seconds..
    how does this happen? too much pressure? speed set to high? both?
    what should I know as a noob?
    39
    19,107
    237
    Re: taking the paint off?
    Well, you really dont want (or from your pics need) a rotary buffer.
    Just a regular Dual Action Polisher will be the best thing, and that already makes things milder and safer. You can look at the Meguiars G220 model to see what those are like.
    But as far as why damage would happen, yes, it would be too much speed, too much pressure, and too much time in one spot. Some combination of the 3.
    Apr 2012
    M
    160
    9
    Also a bad technique, too agressive pad and compound.
    Mar 2013
    United Kingdom
    47
    7
    thanks for the info, was just curious really.
    Team Hybrid Webguy PlayHard's Avatar
    Dec 2012
    South Pasadena
    41
    7
    OMG that is my feat too!!!
    Registered Member Detailing by M's Avatar
    Jul 2011
    Plano Tex-***
    2,202
    31
    Well I know others have broken through/burned paint. In my 30+ years I have never done this. I've just always been careful, something I have always done with power tools. So I'd say you'll be just fine. Use common sense and don't go crazy and treat the tool with respect.
    Sep 2008
    west branch, michigan
    94
    12
    Quote Originally Posted by Please Wash Me Detailing View Post
    im justa greenhorn, but find this advise very good. keep the buffer moving. dont be a fraid to stop and lay the back of your hand on the surface. if its hot, yer over working that area. the buffer will build up a lot of heat real quick if it is set in one spot, which will cause burn through. let the buffer,pad, and compound do the work. it doesnt need to be forced down onto the surface. top speed of the buffer isnt alwy necessary,either.
    a good suggestion is to go to the scrap yard and pick up a hood/fender and practice.
    just take you time and check your progress often. i also use a dual action buffer for final polish. it is noext to impossible to mess up a paint job with a dual action . its what i started with and there are jobs i stick specifically with it.
    Jul 2011
    Plano Tex-***
    2,202
    31
    ^^^exactly
  1. Replies: 7
    Last Post: Mar 5th, 2012, 06:31 PM
  2. "Taking your car's paint to it's maximum potential"
    By Mike Phillips in forum Detailing 101
    Last Post: Jul 14th, 2010, 02:18 PM
  3. Taking care of new paint
    By TNMom in forum The Break Room
    Last Post: Jan 25th, 2010, 01:55 PM
  4. Replies: 5
    Last Post: Nov 4th, 2006, 09:00 PM
  5. Taking the PC plunge
    By SolarA853 in forum Detailing 101
    Last Post: May 17th, 2004, 06:32 AM
