I'm looking to get a pressure washer for the vehicles clean for this company and I was wondering what is best kind out there and that has different nozzle adjustments.
pressure washer help?
They all work the same. But the more expensive ones last longer. You can get a cheap electric one that'll work just fine. I did that or a cheap gas powered for couple 100 bucks and that's what I'm using now. it's working just fine. Tips are what you want just the different degrees of spray is the differance. I use a 15 others like a 30
Re: pressure washer help?
Also don't forget about the PSI. I'd stay 2700 PSI (highest) and go down from there. Any higher can cause damage to the paint. I have also been searching for one, but not sure yet. I've also looked at Generac brand. Not sure about how well they hold up. I believe it was 2700 PSI for $299.
We have one at work that has 4 interchangeable tips on it. I can't remember what brand, but it's been really good. I'll try to get that info tomorrow.
