Tire dressing and interior dressing replacements?
  • Tire dressing and interior dressing replacements?
    If I choose to go detailer line, what do you guys use in replce of Hot Shine Tire Foam, Endurance for tires and what would you use in replace of Ultimate interior protectant like natrual shine supreme shine etc??
    I'm thinking the D17001 Hyper Dressing is what would replace all those and I'd change the dilution for each??
    Show N Shine Car Detailing - Quality Care, Each and Every Time
    Re: Tire dressing and interior dressing replacements?
    Yeah... although being ok for everything usually means not as good for one thing.
    ASD would probably be the most durable in that line for tires and exterior trim. But a bit greasy on the interior stuff.
      Try Meguiars Tire and Trim dressing from the Detailers line.
        I don't think much can replace Ultimate Protectant.
        It is the one water based dressing that can stay longer than typical water based dressings, as well as include a good amount of UV protection if i'm not mistaken. I'd personally stick with Ultimate protectant, or if going a bit cheaper use Natural Shine/Supreme Shine.
        Hyper Dressing would be used for interior, exterior, and tires. So the closest thing I believe to your replacement needs would be Hyper Dressing to sum it all in one product. However, I would buy at least 2 spray bottles for different dilutions.
          This would be our suggestion - great stuff. D163 Tire and Trim Gel.
            Thank you for the responses.
              I use an outstanding tire shine made by "Onyx" i have used it for years , 10 actually, i will not use anything else , it lasts at least 6-7 days and it's a med-high gloss shine pump trigger / stream- spray , it's about $8.99 you can get it online , try it out you will NOT be disappointed.
              Coop http://www.hollandercorporation.com/...ay-bottle.html
              "Sometimes the best way to get some ones attention is to stop giving them yours"
                I went ahead and picked up some endurance gel for now. I used to use the gel with the old stuff and I always liked it. I still may pick up the tire and trim gel D163 later on.
                Also thank you for the onyx reference but I'm really in love with meguiars and I know their stuff works. Been using their stuff for over 20 years.
                  There was a good pretty good comparison done on MOL that made me pull the trigger on the gallon size Hyper Dressing.
                  2012 Acura CBP TL SH-AWD Tech
                    I gave in a bought hyper dressing yesterday, I hope it works well!
                      Yep... same here.
                      I think the biggest factor for me going with the Hyper Dressing was not much the longevity since I seem to wash once a week but if my assumptions are right....or at least I hope.... there won't be much of an oily residue that literally destroys any wash media that touches the tires.
