Mid-Year Introduction - D143 Acid Free Wheel & Tire Cleaner
  • #31
    Re: Mid-Year Introduction - D143 Acid Free Wheel & Tire Cleaner
    I just plasti dipped a set of wheels a couple days ago...so I haven't washed yet.
    I do have some pieces plasti dipped like the grill and some emblems....Gold class & Hyper wash soap had no damaging effects on those areas.
    The wheels are originally black, I applied black plasti dip and then some plasti dip copper metalizer....looks great, hopefully D143 would hurt it....
    I guess I will be testing how D143 works on Plasti dipped wheels
    "STRIFE" aka Phil
    • #32
      You will be fine. My brother had his wheels plasti dipped. He ended up removing it but left the dip on the inside part of the wheels. I gave him a spray bottle with D143. He uses it all the time with no issues.
      99 Grand Prix
      02 Camaro SS
      • #33
        ^ Thx for the confirmation, i was 99% sure it would be ok....not a huge issue as wheel dipping is pretty easy and kinda fun
        "STRIFE" aka Phil
        • #34
          I got a question... i am really interested in this product, however i do not know if my wheel is safe to be used with this product lol.
          They are some stock Beadlock Toyota TRD wheels on the Toyota Tacoma Baja Series.
          • #35
            fenderpicks, you can use PlastiDip on virtually anything - chrome, plastic, paint, glass, etc. It will stick to almost anything with practically zero prep (other than ensuring a dirt free surface) and when you're done with it or just want to remove it, it simply peels off.
            • #36
              I just used D143 on my plastidipped wheels and very happy to report it worked great.
              I used a large Daytona wheel brush, along with 2 other smaller boars hair brush....no issues
              Before I applied plasti dip, I usually use Wheel Brightener and APC+.......scrub like mad.
              But you can just spray with an ONR solution and wipe with a towel
              "STRIFE" aka Phil
              • #37
                I told you that you would be ok using it on plastidip. One other thing I noticed with plastidip is that it loses it's luster over time at least on my brothers wheels it did. I ended up trying some tire dressing on a small spot and that brought some life back into it but it only lasts as long as the product lasts on tires. The glossifier works pretty good as does the metalizer if you want some metal flake on your dipped wheels.
                99 Grand Prix
                02 Camaro SS
                • #38
                  Oh sorry i meant the D143 lol.
                  I want to know if my wheels are safe to be used with D143
                  • #39
                    Description:
                    With a formulation similar to our Hot Rims All Wheel & Tire Cleaner, D143 is a non acid wheel and tire cleaner that quickly strips away brake dust and road grime, cleaning not only the wheels but the tire side walls as well. Not to be used on bare aluminum, anodized or powdercoated finishes.
                    2018 Acura RLX Tech - Majestic Black Pearl
                    • #40
                      Yea i read the desc, but idk how to tell the difference lol
                      Idk if mine is bare aluminum / PC / BUT pretty sure not anodized....
                      • #41
                        Fenderpicks, gotcha!
                        If these are a factory OEM wheel, meaning they are clear coated from the OEM, then D143 should be safe to use as directed on the bottle. If you have an aftermarket brake kit with any anodized or aluminum parts, you should stick with our Aluminum Wheel Cleaner or soap and water.
