tape adhesive
Results 1 to 8 of 8
Thread: tape adhesive
    Still Learning KidDetailer's Avatar
    Nov 2008
    las vegas
    144
    12
    tape adhesive
    I thought I was using some okay automotive tape that I got from Harbor Freight. Come to use it, I noticed that this stuff wasn't great at all. It ended up leaving a lot of adhesive residue that was a pita to get rid of. I would of been better off not using any tape at all. I was wondering, what products would be good to get rid of tough adhesive residue that's been stuck on the plastic such as rear brake lights? I tried using clay with poor results. I instead used warm water with car soap...and a lot of elbow grease with a microfiber towel.
    Registered Member SwunMurrieta's Avatar
    Feb 2013
    Avondale,AZ
    125
    8
    Re: tape adhesive
    Use lacquer thinner. It will come off in a few seconds.
    Registered Member Stephan's Avatar
    May 2013
    The Palm Beaches FL USA
    426
    Re: tape adhesive
    Did you have it outside in hot sunlight? Extreme heat can do that sometimes.
    I've only used SCOTCH Blue multisurface original, got it at Home Depot, no problems in hot indoor conditions with no sun.
    2018 Acura RLX Tech - Majestic Black Pearl
    Addicted to Detailing Evan.J's Avatar
    Mar 2008
    566
    16
    Re: tape adhesive
    You can also burn the tape as well. What this means is you take the tape and place it on your clothes to make it less sticky. Also be sure you pull it off at a 90 degree angle.
    Thoryamaha919 AKA Evan
    Registered Member Detailing by M's Avatar
    Jul 2011
    Plano Tex-***
    2,202
    30
    Re: tape adhesive
    WD40 works great.
    Nov 2008
    las vegas
    144
    12
    Re: tape adhesive
    you're right, only the rear tail lights which was hitting the sun seem to have the issue. The garage was hot overall since its like 110deg here. I will try the WD40 method as I have that readily available.
    Jul 2011
    Plano Tex-***
    2,202
    30
    Re: tape adhesive
    Quote Originally Posted by KidDetailer View Post
    .......I will try the WD40 method as I have that readily available.
    Exactly why I suggest it. I learned about WD40 removed adhesive when I was a kid. My mom would remove price stickers from presents she was giving. I never looked back.
    Registered Member Jeremy1980's Avatar
    Jul 2012
    Minnesota
    38
    26
    7
    Re: tape adhesive
    Glad this came up, I have to remove some tape residue from my car as well. I've used Meg's detailing tape and 3M light blue painter's tape. That sun will bake the adhesive on in no time.
  1. To tape or not to tape that is the question!
    By flakybear in forum Detailing 101
    Last Post: Mar 15th, 2010, 07:45 AM
  2. ghost adhesive
    By superAndre in forum Detailing 101
    Last Post: Sep 17th, 2008, 06:20 AM
  3. Replies: 2
    Last Post: Jul 6th, 2006, 06:51 AM
  4. Wax/Adhesive Remover
    By Pete-FWA in forum New Product Suggestions
    Last Post: Jan 9th, 2006, 03:47 AM
  5. 3M trim adhesive tape and NXT
    By AL-53 in forum Detailing 101
    Last Post: Jul 22nd, 2005, 12:06 PM
