DA Power System - Cordless vs hand application.
  • DA Power System - Cordless vs hand application.
    I understand that you need a certain speed to make it fully effective however I was wondering since ultimate compound and polish can be applied by hand wouldnt a cordless drill turning slight slower than recommended still produce a better result compared to applying by hand?
    I rather do it by hand den use a cordless drill... but surely da power system with a good corded drill will do an amazing job
      Re: DA Power System - Cordless vs hand application.
      Well, as has been noted, a cordless drill (which is usually slower speed, lower torque, or both) would be fine for just spreading around a wax or polish.
      The problem with the UC would be if it needs worked in with some pressure, a cordless or real lower power drill might not be able to turn the pad fast enough with pressure applied.
        My cordless 20v dewalt is rated at 2300rpm max. But wouldn't a drill that is slower weaker still produce better results than hand application?
          Ok I tried out the DAPS on my DeWalt cordless drill.
          It has 1700 RPMs and it worked fine.
          The buffer spun at the correct speed and I pushed on it hard enough to grind out any paint defect or the paint itself.
          But your going to need more then one battery if you want to do more then just a spot.
          DetailingByM.com
            I use a drill that was only like $20 from Harbor Freight tool...and it has like up to 3500rpm. It also has Locking trigger and keyless chuck. Works well for the DA power system.
