Meguiars 3" Microfiber cutting pads with DA Power System?
Results 1 to 7 of 7
Thread: Meguiars 3" Microfiber cutting pads with DA Power System?
    Registered Member Duffmancantbreathe's Avatar
    May 2013
    New York
    4
    6
    Hello!
    Has anyone tried to use the Microfiber pads with the DA System? Have some bad swirling I really want to get rid of. Thanks!
    Sep 2005
    Sydney, Australia
    4,280
    63
    Re: Meguiars 3" Microfiber cutting pads with DA Power System?
    Good question! I'm sure somebody has.
    I'd be interested to see how it performs...
    Still Learning KidDetailer's Avatar
    Nov 2008
    las vegas
    144
    I tried the cutting pad on the rear panel of a Nissan Sentra dark blue with Ultimate Compound. It must be my technique, but I made many passes, and put moderate pressure with slow arm movement, but the defect it had would NOT come off.
    May 2013
    New York
    4
    6
    Quote Originally Posted by KidDetailer View Post
    Hey KidDetailer, what defect was it? Was it a deep scratch?
    Registered Member PPLd's Avatar
    Jun 2010
    Hong Kong
    30
    159
    If you refer to my review here:
    http://www.meguiarsonline.com/forums...stem&highlight=
    I was able to 3000g sanding marks using orange pad + D300.
    And I agree that by using MF cutting pads with the DA Power System, you will achieve even more cutting than standard foam pads.
    And if you read through the comments from Mr. Stoops, you can see that his opinion on using MF cutting pads with the DA Power System.
    Hope that helps.
    Dennis
    Nissan Fuga | 日產 風雅 | 日産 フーガ
    Registered Member Detailing by M's Avatar
    Jul 2011
    Plano Tex-***
    2,202
    30
    Yes you can.
    The DAPS is just a small DA powered by a drill.
    So any pad combination can work with it.
    Nov 2008
    las vegas
    144
    Quote Originally Posted by Duffmancantbreathe View Post
    It was not a deep scratch but a WHOLE ROW of swirl's and light scratches that was by the trunk area where people usually "pull luggages" on. It was that painted section of the rear bumper where the DA Power system 3 inch pad would fit nicely over because the surface was about that size. I varied my arm speed from both quick to very slow and also my arm pressure. I believe I went through it with 8 passes at least. That defect would come out maybe if I tried another 16 passes.
  1. Replies: 19
    Last Post: Oct 17th, 2012, 12:11 PM
  2. Replies: 0
    Last Post: May 6th, 2012, 08:35 PM
  3. Microfiber system--why is the 6" backing plate recommended for 6" pads?
    By Ktraughb in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: May 1st, 2012, 08:15 AM
  4. DA Microfiber system, 5" or 6" pads when used with PC 7424?
    By gbackus in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: Apr 20th, 2011, 01:50 PM
  5. Meguiar's wool pads cutting power
    By MandarinaRacing in forum Detailing 101
    Last Post: Apr 30th, 2007, 03:27 PM
