pad choice to use with 105 and 205
  • pad choice to use with 105 and 205
    I am getting a pc and 105 and 205 polishes. I'm looking into the cg hex logic pads and was wondering what pad you would pair with each product. If anyone has any other suggestions on pads please let me know.
    Re: pad choice to use with 105 and 205
    I use these pads. Orange, white and black.
    Lake Country 5 1/2 Inch Flat Pads 6 Pack - Your Choice! - Build your own perfect pad kit! Select six Lake Country 5 1/2 x 7/8 inch Flat Pads in the colors of your choice. You know what pads you need better than anyone. Customize your own pad kit ...
    99 Grand Prix
    02 Camaro SS
      Always good to have a variety of pads. The PC comes with a 6 inch backing plate I believe, I would switch to a 5 inch backing plate and go with 5.5 inch pads. The LC flat foam pads are good and so are the hydrotech and CCS. AG's website describes what each pad is used for.
      Yellow and Orange for cutting=105
      White for polishing=205
      Black for Jeweling=205
      Black for Wax/Sealant=Wax/Sealant of your choice
        Micro fiber or a yellow soft buff pad
        DetailingByM.com
          Microfiber for the 105? Heavier cut I presume? What brand do you recommend?
            ......What brand do you recommend?
            and 205 on an MF pad will cut like crazy.
            DetailingByM.com
              Here is what I use:
              Megs Yellow 6.5" - M105 - Cutting, paint correction.
              Megs Yellow 6.5" - M205 - Polishing
              Megs Beige 6.5" - M205 - Jeweling - This pad has no cut at all (Black pad still has some cut) so I can run the DA at 5 and it really makes the paint talk.
