i have a 2004 tahoe, black. i feel like i've gone at this thing for a while and am not seeing any correction in the paint. i've pretty much only have worked on a couple of areas to try and get a good process down, and i'm not seeing the results. here is my process:
wash (2 bucket method)
dry w/ microfiber
clay w/ QD
this next step is where i have stalled. I have the DA power system. for this step, i am using the maroon pad w/ heavy pressure. i have used a couple different products at different times following the above process each time: Swirl X, Scratch X, and UC. None of which seem to remove swirls or scratches based on my current method. I run my corded power drill as fast as it goes, press down very hard and vary my speed on the passes (very slow to moderate). Here is a pic i snapped last night after using swirl x in this method on the hood:
it seems to me that I would be seeing better results based on the effort that i'm putting forth. does anyone know if the Tahoe has hard paint? I'm a newbie so I'm sure it's my technique more than anything. any thoughts?
dry w/ microfiber
clay w/ QD
