Rust stains on garage floor
Results 1 to 10 of 10
Thread: Rust stains on garage floor
    Registered Member mswerb's Avatar
    Cleveland, Ohio
    47
    148
    What is the best way to remove rust stains from my garage floor?? I bought a masonry and cement degreaser from Lowe's and the stain laughed at it. I have heard that toilet bowl cleaner will work? Any input is greatly appreciated.
    39
    19,182
    237
    Re: Rust stains on garage floor
    Is it just a surface stain?
    I wonder if you could contact the IronX folks for an idea... It certainly changes color when hits iron in the driveway...
    Nov 2010
    Vancouver
    1,218
    22
    First thing that comes to mind is CLR
    http://www.youtube.com/watch?v=T0npiNnEMXo
    "STRIFE" aka Phil
    Sep 2005
    Sydney, Australia
    4,310
    65
    I thought about CLR as well.
    It might be a bit tricky if the stain has worked its way into the pores of the concrete (below the surface). Worth a shot though.
    Or do what I did.... epoxy paint your garage floor. That will cover a multitude of sins and it's very hard wearing.
    Cleveland, Ohio
    47
    148
    I also heard the Barkeeper's Friend works. I just happen to have some of this on hand and will try it out this weekend. I'll try to post pictures.
    Cleveland, Ohio
    47
    148
    So I tried the Bar Keepers Friend with no luck, but after some research I found out that toilet bowl cleaner would be my next best thing to use. Here is what I discovered.
    Before.
    And after.
    Aug 2010
    Fairmont, MN
    77
    1,442
    24
    What brand of bowl cleaner?
    TIA...
    Bill
    Cleveland, Ohio
    47
    148
    I believe it was Lysol, the gel kind.
    Aug 2010
    Fairmont, MN
    77
    1,442
    24
    Thanx!
    Bil
    Aug 2018
    Amsterdam
    4
    I apologize for bump the old topic, but I have some interesting observations that I would like to share, maybe this will help someone in the future because once I was on the lookout for useful advice.
    I have a 3-car garage, and at first tried the water based product sold at HD on part of the floor. It flaked off badly but I think most of that was due to poor surface preparation. The second time, 8 years later, I decided to tackle it again. This time it turned out great, well worth the $ and hours involved for DIY. To do it right (DIY) I recommend:1. Do the whole floor. If that means renting a POD and putting all the garage stuff in the driveway for a month, it's worth it.2. Degrease/scrub, rinse, acid etch/scrub, rinse very thoroughly, let dry for 2 days.3. Use solvent based epoxy https://mechanicguides.com/best-garage-floor-cleaner/ for best results, not available at HD/Lowes as far as I know, but available at Grainger and elsewhere: http://www.grainger.com/product/RUST-OL ... -Kit-1TBG4 Use a respirator and/or have really good ventilation.4. Put down 2 base coats, and one clear coat. The clear coat you can buy at HD. As you put down 2nd base coat, sprinkle with flakes then seal with clear coat the next day. Add sand (included) to clear coat before rolling it. It provides really good traction when wet. Use really good lighting with the clear coat because it's easy to miss spots.Cleaning, etching, drying, and painting 3 coats will **** the life out of you and take 5 consecutive days, (not including moving all the **** in and out) but it's worth it. After 3 years the floor cleans easily and looks amazing.Enjoy your new floorOn YouTube there are a lot of interesting videos on this topic, I will share with you, one of them, hope this will help сомеоне.Good luck
  1. Removing stains from rust
    By CumminsCrazed in forum Detailing 101
    Last Post: Jul 14th, 2013, 07:45 AM
  2. Rust stains on leather seating surfaces
    By DaGonz in forum Interior Care
    Last Post: Nov 14th, 2011, 04:37 PM
  3. New Garage Floor
    By JLB768 in forum The Break Room
    Last Post: May 21st, 2011, 11:36 AM
  4. Rust stains
    By 00Blazer in forum Working by Hand
    Last Post: May 10th, 2011, 06:22 AM
  5. floor mat stains
    By sudsbyhubbs in forum Interior Care
    Last Post: Sep 8th, 2008, 06:23 PM
