Lowrider Magazine - Project FearleSS
Results 1 to 10 of 14
Thread: Lowrider Magazine - Project FearleSS
    Trabuco Canyon, CA
    21,381
    1136
    A few weeks back we had the privilege of working with Lowrider Magazine on their Project Fearless, a 1968 Chevy Impala that they're currently building. Recently shot in all black but from from final assembly, Lowrider asked us about doing a wet sand and full buff out on this black beauty. So we called in a few friends, namely Kevin Brown (buffdaddy.com), Joe Fernandez (superiorshine.com) and Derek Bemiss (detailwerks.net) to help out Meguiar's employees Jason Rose, Mike Pennington and myself. This is a big car, and it was going to be a big project. We needed some big guns!!! We can't thank these guys enough for offering to help out; we couldn't have done it without them!
    Don't miss the time lapse video at the bottom of this post - it's pretty awesome!
    We had a fair bit of dirt nibs and orange peel to deal with.
    Tools of the Trade - Part 1.
    We started out doing some testing to see what overall process would return the most efficient removal of orange peel, dirt nibs and other issues while providing a surface uniform enough to allow for minimal buffing time to return the paint to a high gloss finish. We started with 1500 grit hand sanding.
    We worked up to 3000 grit DA sanding to maximize our sanding mark refinement.
    This is the sort of finish we obtained with the test area. This is after compounding with M100/wool pad/rotary buffer. There is no finishing polish at this step.
    Once we determined the process it was time to get to work.....and maybe even have some fun along the way.
    On Day 1 we even got some help from the painter and shop owner.
    Kevin Brown doing his thing.
    Early stages of hand sanding....... not good enough. Not even close. Keep sanding!!
    Much better! A nice uniform 1500 grit sanding pattern, done by hand. This has effectively leveled the paint and it's time to start the refining process.
    Some areas presented a bit more of a challenge as tighter radius concave sections needed some extra care.
    Normally you want to have a foam backing pad behind the sandpaper, but this radius was too tight. Kevin is moving the sandpaper mostly side to side here, not back and forth as that could leave finger groove pressure points. That would be bad.
    Joe Fernandez working the roof, and keeping a close eye on his progress.
    Jumping well forward in the day now, and Mike Pennington hand sands the tricky area at the bottom of the C pillar. The rear quarter panel line peaked here, with a very tight radius curve sweeping up as the C pillar came down to meet the quarter panel.
    Refining the hand sanding marks with a DA sander - 1500 grit finishing disc followed by 3000 grit finishing disc.
    We can't forget the dash, painted at the same time as the rest of the car and so sanded at the same time as the rest of the car. Mini air tools come in really hand here!
    At the end of the day the car no longer looks black, but more of a gunmetal gray. With sanding refined to 3000 grit we've even got some halfway decent gloss returning. But the car is supposed to be black, not gunmetal, so we've still got a lot of work ahead of us.
    Tools of the Trade, Part 2.
    Day 2 and it's time to start compounding. Derek Bemiss was on hand for this process and, here, he and Mike Pennington discuss some small areas that still show some issues.
    Jason Rose, in full protective gear, using M100 on a 4" foam cutting pad to work the tight areas at the base of the C pillar.
    Now we're really getting some shine back!
    No, Joe didn't stand in one spot for two days - in the earlier picture above he was sanding on the other side of the roof! He constantly inspects as he goes, putting his critical eye and massive skill set to constant use.
    M100 Pro Speed Compound - it did everything we asked of it on this day, and more. Great stuff!!
    The team in full attack mode.
    Kevin doing his thing. Again.
    Jason and I continue working on that gloss, eradicating sanding marks on areas large and small.
    Joe works that tight radius where the C pillar and quarter panel top create a very tight radius concave curve.
    A bit more experimentation to remove light buffer swirls, and we decided that M205 on a foam polishing pad with the rotary set to roughly 1000 rpm was the ticket.
    Mike and Mike..... but, um, where did everyone else go? Well, this is Day 3 of the project and the other guys could only offer up so much time. Mike and I are here all the time so we continued on without the rest of the crew.
    As a final step and just to really make things pop, we gave the car a quick once over with M205 on black foam finishing pads via G110v2 DA.
    After almost 3 full days, plenty of sand paper, M100, lots of sweat and plenty of good times, we end up with this:
    And this:
    And this:
    A couple of days later a flat bed trailer showed up to reclaim Project FearleSS and haul her away for final assembly. We couldn't resist taking a few more pictures out in the sunshine as she was loaded onto the trailer.
    Off to get an interior, drive train and everything else installed. Looking forward to seeing the finished car on the show circuit in the coming months! And a huge Thank You! to Lowrider Magazine for allowing us to assist with this critical part of Project FearleSS.
    Registered Member Detailing by M's Avatar
    Jul 2011
    Plano Tex-***
    2,202
    30
    Re: Lowrider Magazine - Project FearleSS
    Nice N Cool Job!
    Don't forget to post the Mag pics too!
    I've never experienced Nibs like those. How were those handled? Any De-Nibbers used?
    (I still wish I could have stopped by... for the pizza)
    Sep 2005
    Sydney, Australia
    4,283
    63
    Wow, beautiful work guys!
    Those reflections are so crisp without orange peel!
    Sep 2008
    Sydney, Australia
    1,347
    24
    Fantastic work! Full marks to all that took part in this massive correction job. That paint looked quite nasty to begin with, with quite a bit of everything wrong with it!
    Great turnaround!
    Aug 2010
    Fairmont, MN
    75
    1,382
    22
    Outstanding!
    I see work like that and I'm speechless...
    Bill
    Dec 2009
    Iowa
    2,631
    39
    That much talent and years of experience in a two-car garage is pretty impressive on it's own merits.
    You could probably read the wattage of the lamps on the ceiling in the reflections on the hood.
    The song "Clarity" comes to mind.
    David
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Jan 2009
    San Diego, CA
    2,310
    60
    I've gotta find a way to slip my car in there when the dream team gets together do a project like this! AWESOME JOB just seems like an understatement.
    Paint correction is not a process, it's an art when performed on this level. Congrats Mike, Mike, Kevin, Joe, Jason, and Derek!
    Registered Member Psynx's Avatar
    Apr 2012
    United States
    286
    9
    the best of the best working together, man i loved to be there just to watch this all star team work magic lol
    If you like my work please like my FB page
    https://www.facebook.com/Ultimatecardetailingoc
    I am the paint whisperer. Superior Shine's Avatar
    Feb 2004
    Covina / Los Angeles
    4,734
    205
    Much FUN!! I was flattered to have been invited to help.
    Registered Member juho's Avatar
    Nov 2010
    Gwacheon-si, Gyeonggi-do, Korea
    3
    9
    It's awesome team's art!
  1. A day with Automundo Magazine
    By Michael Stoops in forum The Break Room
    Last Post: Apr 3rd, 2010, 03:23 PM
  2. Magazine's
    By TRIPOWER1 in forum The Break Room
    Last Post: Feb 12th, 2009, 11:02 AM
  3. Wax It Magazine
    By akimel in forum The Break Room
    Last Post: Nov 24th, 2008, 06:00 PM
  4. You could be on the cover of S3 Magazine!!!!
    By J-rod in forum Car Shows & Industry Events
    Last Post: Jul 6th, 2006, 03:19 PM
  5. In a magazine...
    By Aurora40 in forum The Break Room
    Last Post: Oct 13th, 2005, 05:53 AM
