Premier Auto Detailing by Evan: 2013 Honda CRV Opti-Coated
  • Premier Auto Detailing by Evan: 2013 Honda CRV Opti-Coated
    Well on tap this weekend was a beauty a 2013 Honda CRV. The paint was not in bad shape at all a few light swirls and just a few RIDS here an there.
    Exterior:
    • Wash with CG Wash and Clear Red
    • Wheels cleaned with Megs wheels Brightener and then sprayed with with then new Iron-X
    • Tires cleaned with Megs Non Acidic Wheel and tire cleaner with a foam sprayer
    • Chemical Decontamination with Iron-X over the exterior surfaces
    • Clayed using the Speedy Prep DA pad and the towel for the tighter areas
    • All trim taped off
    • Test spot done
    • Rupes 21 with 5" BP with a BnS polishing pad and M205
    • After polishing the entire vehicle was wiped down with CarPro Eraser
    • Finally Opti-coat was applied to all exterior surfaces.
    • Tires were dress with with Opti-Bond tire gel
    Some before photos:
    After photos:
    Thanks for looking!
    Thoryamaha919 AKA Evan
    Re: Premier Auto Detailing by Evan: 2013 Honda CRV Opti-Coated
    Looks great! Crisp and sharp reflections. Well done!
      Very nice work!
      So did you also OC the trim and glass?
        Very nice work!
        Thanks. I did do all the trim but no glass.
          Nice one.
          The trim is looking really good. Would you say OC enhances the appearance of exterior trim, or was it already in good condition?
            Nice one.
            As always proper rep is the most important key to getting the best finished results. With thats said with everything that I did to the paint enhanced the gloss much more than it was in its original state. I think OC added a certain glossy wet look when applied to a properly prepped paint.
              Yeah, but what about the trim? (think you mis-read my question)
                HAHA Yea I did. I think it added a little bit of enhancement but not much. The trim was in good condition to begin with.
                  Thanks for the info
