I have been readin a bit and watching you tube etc... and have never really detailed a car or even waxed one by hand.I have a 1970 mustang mach one that I had sanded and then polished and it was in very bad shape.I am contemplating taking it back in the spring to have more of the scratches taken out and polished some more OR buy a economical DA like the one from HF and then buy the needed pads and products and do it myself.I am very handy with tools and very particular and good at following directions.I have watched all the 5 parts of the Junkman2000 you tube vids on novice usinga DA and see that it does not look all that bad.I figure if i could remove the rest of the small shallow scratches myself and then use use the DA for polishing and waxing then I would have the pride of doing it myself and have a tool i could use for upkeep of the paint.Am i dreaming or should the DA stuff and polishing be something people with more experience should handle.I feel even after the sanding that there is a decent amount of clear on the car an The guy that did the work said the clear was soft.
Thanks guys , This is my 1st post.
