DA Microfiber Polish - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: DA Microfiber Polish
  1. #31
    21,405
    1140
    Re: DA Microfiber Polish
    So does this have even less cut than UP?
    It's very different from UP. In and of itself it has less cut than UP, but it also won't hide as effectively as UP will due to the polishing oils in UP. It's really designed for someone wanting to stay within the microfiber system but increase the overall quality of finish. That said, on foam finishing pads it works extremely well, too.
  2. #32
    Nov 2010
    Vancouver
    1,218
    23
    Will D302 be available in larger sizes?
    I'm thinking for myself, this would be step one of a two step detail on my cars when using the DAMF system if doing a 1 step with D301/finishing MF pad is not enough.
    "STRIFE" aka Phil
  3. #33
    Dec 2009
    USA :)
    131
    This really is a case where the product is quite single minded in it's purpose.
    I really like that. A true finishing polish.
  4. #34
    Registered Member Detail Supply Plaza's Avatar
    Dec 2013
    San Diego, CA
    8
    We will have this product available online shortly and in our brick and mortar early Q1 2014..
    Check us out at detailsupplyplaza.com
    Jane
    Last edited by Markus Kleis; Jan 27th, 2014 at 07:10 PM. Reason: No hyperlinks before 30 posts
    Jane
    detailsupplyplaza.com and
    janecosales.com
  5. #35
    Registered Member J4o2el7's Avatar
    May 2011
    Tacoma Washington
    155
    12
    Has anyone tried this on aftermarket paint? This may cure my current problem I posted in detailing 101, sounds like it might, and I maybe have to put it off for one more weekend if so. The mf system used on my job left a lit of da haze..... So this may fix it, but mur suggested a 205 on a finishing pad, and don't doubt him at all, he has been here a long time, but just wondering if this may work on the aftermarket paints as well.
  6. #36
    21,405
    1140
    Quote Originally Posted by J4o2el7 View Post
    There is no reason why aftermarket paint should pose a problem for this product. We just responded to your question in the other thread but we'll add to it here: without seeing the level of marring you have on the car in question, and without having worked on it personally to get a feel for just how it's behaving, it's a bit difficult to emphatically state "do this and everything will be fine". Our first recommendation is to use material you already have on hand. If that's M205 and a yellow polishing pad, that would be our first choice. Step up to Ultimate Compound from there if need be. In fact, if you do not have either of those, you could actually give D300 a go on the yellow foam pad. I neglected to mention this in the other thread, but as I think about it I have worked on a specific car where the DAMF system hazed it badly but D300 on yellow foam was a dream! I had a very limited selection of liquids with me on that day, and this was the first time I used that combo, but it worked like a champ.
  7. #37
    May 2011
    Tacoma Washington
    155
    12
    Thanks, sounds good, I have the yellow pads and D300 and the UC , i dont have the 205 yet, was going to go grab some, but maybe i will give this a shot first. Thanks for the pointers
  8. #38
    Mar 2014
    LaHabra, California
    8
    polish is a great new product I have used it in a couple different ways already, I have used it as a one stage with the finishing pad lots of shine and no haze its perfect for the customer who does want to spend the money for full correction and I have used it in the three stage paint correction it was designed for ... great product meguiars
  9. #39
    Milwaukee, WI
    99
    I typically use Ultimate Polish with a black foam pad after I use the D300 and the Microfiber pad then I wax it with UW also with a black pad. Now I have the choice of using D302 polish with a foam pad or Microfiber pad. Is either one better than the other?
  10. #40
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,648
    67
  1. Replies: 4
    Last Post: Aug 13th, 2013, 04:53 AM
  2. Replies: 4
    Last Post: Aug 25th, 2012, 04:42 AM
  3. Deepest shine: Deep crystal polish or ultimate polish ?
    By aqueelmole in forum Detailing 101
    Last Post: Jan 18th, 2012, 06:00 AM
  4. Replies: 9
    Last Post: Sep 11th, 2011, 06:49 PM
  5. Foam or Microfiber for Ultimate Polish?
    By 94LT1Z in forum Detailing 101
    Last Post: Aug 19th, 2011, 05:30 AM
