Xtra Cut Microfiber Discs - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: Xtra Cut Microfiber Discs
  1. #11
    Registered Member jankerson's Avatar
    Oct 2013
    United States
    160
    9
    Re: Xtra Cut Microfiber Discs
    Thinking about how M105 would work on those.
  2. #12
    Corvette Crazy Detailer RDVT4ME's Avatar
    Apr 2004
    Yorba Linda, Ca
    1,093
    28
    Mike,
    I assume this pad will also generate a lot more heat and folks trying this for the first time should be aware of that.
    -Bob
  3. #13
    Nov 2010
    Vancouver
    1,218
    23
    Sounds like these pads are designed to cut faster, not necessarily cut more than the original cutting pads....so just a time saver for the pro detailers?
    Will these be available in 3" versions...seems to make sense?
    "STRIFE" aka Phil
  4. #14
    CCH Auto Appearance, LLC C. Charles Hahn's Avatar
    Dec 2012
    Lansing, MI
    85
    9
    Quote Originally Posted by RDVT4ME View Post
    Mike,
    Agreed; I also wonder about delamination issues due to heat, and the possibility of welding the pad to the backing plate -- especially if they are used with a non-Meguiar's plate (e.g. Rupes polishers).
    Interesting concept though, might even allow for tuning performance by adding one or more sanding interface pads between this and the backing plate.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
  5. #15
    21,405
    1140
    More cut vs faster cut is sort of a matter of semantics, isn't it?
    As to the issue of potential heat, yes, there can be more and this is definitely taking the aggressiveness of the DA buffer up yet another notch. But as long as you're not leaning on the darn things, we aren't really seeing any more heat at the backing plate/pad interface than we do with the red foamed cutting discs.
    Now, as we all know, the more the aggressiveness goes up, the more safety comes down - at least to some degree. So, yes, you'll want to be a bit more cautious on sharp body creases and older, thinner paint. As with everything else in this process, common sense goes a long way. Charles, you bring up a very interesting and astute point - having played with these pads a fair bit (and they do indeed cut like crazy on very hard paint) with an without a foam interface pad between it and the backing plate, I can tell you that you can indeed do a bit of "tuning" if you so desire. You will, however, notice an immediate reduction in cut by placing an interface pad into the mix.
  6. #16
    21,405
    1140
    Quote Originally Posted by jankerson View Post
    No need to hide, we know people love M105, M101 and M100 on microfiber pads. And, yes, M100 is just a defect cutting demon on these.
  7. #17
    Nov 2009
    Stang Island, NY
    791
    19
    Good stuff, can't wait to try these out.
  8. #18
    Sep 2005
    Sydney, Australia
    4,313
    66
    Brilliant! These will be great when things need to get really aggressive
  9. #19
    Dec 2012
    Lansing, MI
    85
    9
    That's sort of what I was thinking/hoping; with the variety of interface pads available from different sources made of different materials, it introduces a new variable to dial in cutting ability -- potentially even making them less aggressive than the MF finishing pads if the interface is thick and soft enough. Might even make the regular MF cutting and finishing pads unnecessary, if alternative interfaces work as well as I'm envisioning. Definitely something I'll be playing with as soon as I can get my hands on a few of these pads.
    Charlie
  10. #20
    Oct 2013
    United States
    160
    9
    Have the 5" Pro backing plate and some MF Cutting Discs coming to see how they work for me, haven't tried the MF discs yet, will be using M105 with them.
    But if they bridge the gap between the DA and rotary like they are supposed to I am sure I will be happy.
    I do miss my rotary and wool pads......
    I do want to get that Light Weight Flex rotary soon though.....
  1. Which discs for new clear ?
    By adrynalinjunkie in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Aug 8th, 2012, 08:02 AM
  2. What pad cleaner recommand for DA Microfiber Cutting/Polishing Discs ?
    By brianych in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: May 14th, 2012, 12:47 PM
  3. DA Microfiber Discs Have a Storied Past...
    By Kevin Brown in forum The Break Room
    Last Post: Jul 18th, 2011, 05:13 AM
  4. D/A Microfiber Discs & Polishing
    By DetailArtist in forum Marine/RV - Boats, Motorhomes, Etc.
    Last Post: Apr 4th, 2011, 06:56 AM
  5. Ungrit Sanding Discs & Finishing Discs
    By Michael Stoops in forum Meguiar's 2010 New Products
    Last Post: Apr 14th, 2010, 06:39 PM
