crack in wax
  • crack in wax
    Hi Guys.
    I received #26 paste in condition shown below (crack in wax). I this OK
    Thank you
    Re: crack in wax
    That's very typical of older-style paste waxes. No issue and won't affect a thing.
    Grab your applicator and start enjoying a Meguiar's classic wax.
    Bill
      Re: crack in wax
      Thank you Bill. Now I'm not afraid.
        Re: crack in wax
        Originally posted by kuko View Post
        Hi Guys.
        Thank you
        I hate it when this happens
        When applying wax to your applicator try to keep the level of product in the can even. If you dig a hole in the center it will cause the outside walls to fall in
        Also try mashing the wax back together with your fingers. This method has always worked for me. Another thing I've heard of people doing is placing the can in a pot of water then sticking it on the stove until the product melts. Once it dries; it's solid again! The only problem I have with this method is breathing the fumes
          Re: crack in wax
          This isn't a huge problem. It will be solved the first time you use the product.
          Using your meguiars yellow foam applicator pad, place it into the can flat and twist the pad evenly and gently to add the wax to your pad. Remove the pad from the tin and the crack will be blended back to flat and smooth.
          I don't worry about the appearance of any given wax in the can. It's how it looks when applied to my car that matters.
            Re: crack in wax
            Looks can be deceiving, it should still be perfectly fine. If you lightly run the foam applicator, it would almost instantly reliquify the wax. And the more passes with the applicator, eventually the "crack" will soon be gone.
