Hi guys,
I was wondering if you could give me some advice? A few weeks ago I painted a few motorcycle panels. I did them with spray cans but spent a lot of time on preparation. I used the professional type cans that they mix up for you and then a good brand of acrylic clear. I was pretty happy with the result other than some orange peel. I wet sanded the clear down flat with 1500grit and then 2500grit and then used a lambswool (synthetic?) 3" pad on my cordless drill and Ultimate Compound. I then used an orange foam pad also with UC. The next day I was going to use a finer foam pad to finish when I noticed that there were a lot of parallel crack lines all through the clear when you look at it in the sun, and also random direction lines that you can see when you get the angle right. I swear these weren't there the day before. Could something to do with my buffing technique have caused this? Maybe heat from the pads?
I'm gutted because I spent a lot of time on them and thought I was being really careful throughout the whole process.
Thanks,
Mark
Thanks,
Mark
