Water Spot Remover
Results 1 to 3 of 3
Thread: Water Spot Remover
    Registered Member Rockpick's Avatar
    787
    24
    Water Spot Remover
    All of us who are fanatics cringe when we see the end result of a 'drip' or 'run' down the sides of our vehicle. Those of us with very hard water really cringe...
    While QD sprays can and, sometimes, do work at removal of light water spotting (albeit that they're not really designed for this functionality), I find the spots generated by my water to be exceedingly difficult to remove.
    While I always succeed in removing them, I find myself using a bag of tricks that typically involves removing the wax that is resident on the surface (polish, clay, maybe even dilute vinegar). Naturally, this creates more problems at the end of my trick as I have to reapply a LSP to the affected areas.
    How about a product that can remove safely water spotting and is, generally, wax-safe? This product, as I envision it, could be used for simple touch-ups and not really for a full QD and would simply bring the calcium deposit on the paint back into solution rather than allowing it to continually calcify/harden and, ultimately and potentially, etch.
    Filters are great fine but only provide minimal lifespans and are pretty expensive. Plus, most people don't wash with filtered water; only rinse. The unfiltered tap always finds a couple of body lines or seals to hang on to and then run out once everything is looking good. Air 'blasting' is fine but, again, still seems to miss some spots and the spotting or running still happens.
    Just a suggestion...
    RP
    59
    24,767
    519
    Thank you for your insight and your suggestion!
    Des Moines, Iowa
    41
    5,605
    77
    Rp....
    I like the suggestion! Owning a black truck means you need a few tricks to keep it clean/minimize different problems you might not see on a light colored vehicle.
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
  1. marine line Water spot remover
    By Chex in forum Detailing 101
    Last Post: Oct 6th, 2006, 07:10 AM
  2. Would Meguiar's Hard Water Spot Remover.....
    By EkS in forum Detailing 101
    Last Post: Aug 30th, 2006, 07:49 AM
  3. #47 Hard Water Spot Remover
    By fgraciano1980 in forum For Sale or Trade
    Last Post: Jan 24th, 2006, 05:49 PM
  4. Hard Water Spot Remover
    By RedSoxRacer in forum Detailing 101
    Last Post: Jul 27th, 2005, 04:01 PM
  5. water spot remover
    By DSG Man in forum Detailing 101
    Last Post: Oct 3rd, 2004, 04:40 PM
