I have read a lot of Meguiar's brochure teaching car lover to clean the car (wash, clay, compound if swirl and scratch exist, etc), then apply a polish (mostly pure polish oil product) to enhance the gloss, then seal it with a wax or sealant.
However I have also read a lot in other detailing forum where people after doing cleaning (wash, clay, compound, abrasive polish, etc), then strip the paint chemically first using some sort of product usually called pre-wax cleanser or wax & sealant remover. The purpose is to make sure the surface of the car is only left with the paint itself, not other product on top of it, not even polishing oil. Then a wax or sealant is applied. Of course when discussing this kind of procedure the author always talk about a car with clear coat.
Is the Meguiar's way of doing thing (apply polishing oil, do not remove it, then seal with a wax) not the best practice anymore for a modern clear coat paint? I know applying polishing oil and seal it with wax on Single Stage Paint makes a lot of sense since single stage paint is more porous than clear coat. Hence, clear coat being less porous, is that means the procedure of "applying polishing oil, do not remove it, then seal with wax" should be changed to "strip the paint with cleanser, leave no polishing oil at all on the surface, then directly apply wax" ?
Which practice makes better result (gloss, durability), the apply polishing oil way, or the strip the paint chemically way?
Will be most appreciate if someone from Meguiar's can share their opinions.
I have a bottle of Ultimate Polish. The last time I did was apply it by hand on my car with clear coat. Not intended to remove light swirl, just to give it a layer of polishing oil (because I haven got my hand on the pure polishing oil yet, so I utilize Ultimate Polish for this purpose first), then after wipe clean with a MF towel, I apply a layer of Gold Class paste wax by hand.
Maybe I will next month, stripping the paint down with IPA or Mineral Spirit first, then directly apply a layer of wax without anything in between. No polishing oil. And see what kind of gloss and durability it can give me. But so far the 1st method looking good to me. Not sure if the second method bring even better result.
