Just saw this on the detailing.com's twitter feed. Thought you guys would be interested.
D106 Meguiar's Pro Fiber Rinse & Tannin Stain Remover
D116 Meguiar's Pro Protein Stain Remover
Description:
Meguiar's Pro Fiber Rinse & Tannin Stain Remover is specially formulated to quickly remove tannin stains (coffee, tea, wine, etc.) and pH neutralizes the carpet and seats after using Meguiar's All Purpose Cleaners. Meguiar's Pro Fiber Rinse & Tannin Stain remover will also minimize re-soiling of interior carpets and upholstery too!
Dilution:
Directions:
Directions:
Shake Well. For best results, apply to vacuumed and dry brushed fibers.
RTU Directions:
Extractor or Spray Application Directions:
Pro Tips:
It's best to use Meguiar's Pro Fiber Rinse & Tannin Stain Remover (D106) first (spot clean/RTU), then either Meguiar's All Purpose Cleaner (D101) or All Purpose Cleaner Plus (D103) to the entire carpet or section, then follow up with D106 (20:1) for pH neutralization. pH neutralizing the carpet will prevent the residue left behind by cleaning agents from re-activating on the passengers shoes and re-soiling carpets.
- Fast tannin stain remover (Coffee, tea, wine, etc.)
- Carpet and cloth seats pH neutralizer
- Minimized re-soiling
Dilution:
- RTU (Ready to Use) - Tannin stain and water stain or browning removal
- Up to 20:1 for extractor or spray application
Directions:
Directions:
RTU Directions:
- Apply Meguiar's Pro Fiber Rinse & Tannin Stain Remover (D106) directly to the tannin stain using a 16 oz. dispenser bottle (D9916). Pull the nozzle up at the first position before dispensing the product
- Using a carpet brush, wrap with a cotton towel for carpet applications and wrap with a Meguiar's Ultimate Wipe (M9910) for all other fiber applications.
- Bonnet clean (wrap towel around brush) the stain or use a tamping method (lay towel over stain, pound brush firmly with a succession of blows on towel where stain exists), while rotating the towel when soiled.
- Repeat steps 2-3 above until desired results are achieved.
- Mix up to 20:1 (up to 6 ounces per gallon) with clean water in your solution tank or trigger sprayer.
- For Extractor - Follow extractor manufacturer instructions to rinse the fibers.
- For Spray Application - Spray onto stained surface and back brush (work the brush into the surface) to neutralize the fibers.
Pro Tips:
Description:
Meguiar's Pro Protein Stain Remover is a pre-spot removal formula that quickly and effectively removes protein stains (milk, food, and organic matter) off carpet and upholstery fibers. Meguiar's Pro Protein Stain Remover will also dissolve urine stains and neutralize urine odors.
Dilution:
Directions:
SHAKE WELL. For best results, apply to vacuumed and dry brushed fibers.
RTU Directions:
Diluted Applications:
Pro Tips:
Do no leave the bottle open or exposed to sunlight. Once mixed with Pro Fiber Rinse & Tannin Stain Remover (D106), the solution will last 8-10 hours. Never apply any cleaners directly to the upholstery.
- Fast protein-based stain remover (Milk, food, and organic matter)
- Effective on microfiber interiors
- Concentrated formula
- Contains no added fragrance
Dilution:
- RTU (Ready to use) - Severe protein or urine stain
- Diluted - Add 3 oz. of D116 and 6 oz. of Pro Fiber Rinse (D106) to 23 oz. of water in a 32 oz. secondary bottle. (cut each in half if using a 16 oz. bottle)
Directions:
RTU Directions:
- Apply Meguiar's Pro Protein Stain Remover (D116) directly to the stain using the 16 oz. dispenser bottle (D9916). Pull the nozzle up a the first position before dispensing the product.
- Bonnet clean (wrap towel around the brush) the stain with a tamping method (lay towel over stain, pound brush firmly with a succession of blows on the towel where the stain exists), while rotating the towel when soiled.
- Add 23 oz. of water to a 32 oz. secondary bottle. Add 3 oz. of Pro Fiber Rinse & Tannin Stain Remover (D106), and then add 6 oz. of Pro Protein Stain Remover (D116). If a 16 oz. secondary bottle is used then cut the ounces noted above in half.
- Apply directly to carpet stains. For upholstery stains, apply directly to the towel using the bonnet cleaning method above.
- Extractor Application - Follow extractor manufacturer's instructions using Meguiar's Pro Fiber Rinse & Tannin Strain Remover (D106) to neutralize the fibers.
or - Spray Application - Spray Pro Fiber Rinse & Tannin Stain Remover (D106) to the fibers and back brush (work the brush into the surface) to neutralize the fibers.
Pro Tips:
