what is causing residue to occur? M105 with W8000 pad
Results 1 to 10 of 11
Thread: what is causing residue to occur? M105 with W8000 pad
    Registered Member WhiteLX's Avatar
    Sep 2008
    Riverside, CA
    43
    89
    1989 Mercedes 560 sec. original paint
    I am using a Makita rotary on level 3 (1500rpm) with an 8" W8000 pad. Outside temperature is approximately 64 degrees. I am in the sun, but the body is cool to the touch. This occurs after approximately 15 seconds of buff time. The only way to get it off is to soak the area in M34 and wipe down firmly with a microfiber. A light mist of M34 and more buffing does nothing.
    The car has not been buffer or waxed in years. It been sitting outside and the paint is in terrible condition, possibly very dried out. It does have some clearcoat failure on the top surfaces. I used M80 on a W8000 pad as well, but resulted in the same difficult to remove residue being left behind.
    1992 Mustang 5.0L turbo notchback
    1986 Merkur XR4Ti 2.3L turbo
    1998 Explorer 5.0L
    Sep 2005
    Sydney, Australia
    4,312
    66
    Re: what is causing residue to occur? M105 with W8000 pad
    Too much product?
    Sep 2008
    Riverside, CA
    43
    89
    could have been. Although I wasn't using all that much. I ended up switching to a wool pad with the 105 and it worked much better. Only got a fender and hood completed this afternoon, so I still have a lot more to do. Not sure if I'll follow up with M205 or M80.
    1998 Explorer 5.0L
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,612
    66
    Looks like you over worked the product to the point that it dried out on you.
    Sep 2008
    Riverside, CA
    43
    89
    This was occurring just after spreading the product. I was able to work it far longer than 15 seconds on the wool.
    1998 Explorer 5.0L
    Sep 2008
    Sydney, Australia
    1,354
    26
    M105 can dry up fast on older and/or neglected surfaces. M80 would usually be my recommendation then follow with M105, but if that's doing the same for you....
    How are you applying the product? Directly to the pad or a strip on the paintwork you pick up "on the move"?
    Sep 2008
    Riverside, CA
    43
    89
    On flat surfaces I was applying it to the paint and picking it up. On vertical surfaces I was applying it to the pad.
    1998 Explorer 5.0L
    Sep 2008
    Sydney, Australia
    1,354
    26
    Try to work in the shade or garage if you can. I know that's not always possible...
    I'd clay the paint first. How does the paint feel after the clay? Should be smooth to the touch.
    'Prime' the foam pad to begin. Add a bead of product to the panel to pick up as you've been doing and buff a small area. Maybe 12"x 12" max. Use a lower speed on your rotary and move slowly over the area keeping an eye on the area as you go and keep the pad flat against the panel. Don't overwork the product. Try one section pass and check your results. The idea of the M80 is to hydrate the paint and that should make the paint more user friendly for a next step compounding with M105.
    Just thinking here, but you are using a clean, dedicated pad for M105 and a different one for the M80 right? Have you used a rotary before and if so, how we're your results then?
    Registered Member Detailing by M's Avatar
    Jul 2011
    Plano Tex-***
    2,202
    32
    WAY TO MUCH PRODUCT.
    This is the most common mistake,
    You only need a few drops AND THAT'S IT.
    I maybe use a couple of onces of product for the whole car
    Sep 2008
    Riverside, CA
    43
    89
    Quote Originally Posted by Selectchoice View Post
    Yes. Typically I use a wool pad with M105, this was the first time I tried a foam pad. I've had great results in the past with the wool pad.
  1. Replies: 8
    Last Post: Sep 3rd, 2010, 11:44 PM
  2. I keep causing swirls but I don't know from where.
    By Onefire in forum Working by Hand
    Last Post: Jul 24th, 2009, 07:35 PM
  3. What makes orange peel occur? Can You Stop it?
    By Carfire in forum Detailing 101
    Last Post: Sep 19th, 2008, 03:59 PM
  4. Wot's causing this?????
    By Justin in forum Detailing 101
    Last Post: Apr 27th, 2006, 05:42 PM
  5. 80 causing marring by hand?
    By kev4bama in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Mar 5th, 2005, 08:49 PM
