Another enthusiastic group, and some long drives to here this time around with folks driving in the night before because of the distance! We appreciate so much that people are not only willing to spend a Saturday with us, but to drive many hours just to get here!
As per usual, we selected a car that was driven to the class that morning, and in this case it's a Honda Accord in desperate need of some TLC. Even with this slightly out of focus picture you can clearly see the swirls and etchings that need some serious work.
Our first order of business was to remove any loose contaminants from the hood (we used D115 Rinse Free Express Wash for that) and then we clayed.
This is from just a small area on the hood, which explains the very rough texture we felt.
Clay attack!!!
Ultimate Compound on a W8207 foam pad at speed 5 with moderate pressure. Our typical starting point for a test spot.
Changing direction; you can see the side to side pattern in the image above, and the up and down pattern in the image below. Work the area thoroughly in two directions to ensure full coverage and uniform defect removal.
The next step was Ultimate Polish with a W9207 foam finishing pad.
On the other side, the DA Microfiber Correction System
Not too shabby for one pass!!!
Father and son going to town on their car.
And then we turned more students loose on the hood to finish it up!
Clay attack!!!
