Hi guys from here and Meguiars, (BTW I am a huge fan of Meguairs and have been using numerous Meguairs product line)
I like to wash my car frequently as i find it easier to wash the car clean if car is not so dirty (+ you would have more time & energy after the wash to do Detailing!)
i understand that for waterless method, there is Wash & Wax Anywhere. But since i need to wash the Microfiber towel after using WWA, i was thinking i might as well use rinseless system with bucket (where i can wash the car and the MF towel together) (car is parked in garage and for those days you want a quick wash where u dont want to shift the car out to rinse with hose)
As such i like to ask:
1) Can I use Ultimate Wash and Wax using rinseless method? meaning: dilute it, probably spray some of the solution on car, soak MF Towel with the shampoo and wipe the car, rinse the dirty MF towel using 2 bucket methos and repeat. if need to clear suds on car, use a MP Towel soak with water only to wipe through.
(i using this product line as as example as it contains wax properties and should be more lubricating as prevent swirls,etc).
2) Anyone wash their car using the above method?
3) Assuming i have thorough washed my car say a few days back and now just want to clean up the light coat of dust can i use the above method for a quick fix?
4) is it safe? will it cause swirls or streaks? any disadvantage or any important things to take note?
5) any other comments or suggestion or advice much appreciated.
Thanks
Thanks
