question on Velcro backing.
Results 1 to 2 of 2
Thread: question on Velcro backing.
    Mar 2014
    Iowa
    4
    6
    Question on a Velcro backing. Bought a variable speed rotary buffer as a starter. It came with a 7" vel cro backing. I purchased 2 microfiber bonnets (hook and loop? There the ones that slide on top). Question is can those be used on the Velcro or should I get another backing? It just seems the Microfiber bonnet is to thin to have Velcro behind it. I also bought a 5/8 arbor 8 inch foam pad for the buffer paid a little more for it. Are the foam pads able to stick to Velcro or are they hook and loop. The one I bought had the 5/8 arbor in it already but it was pricy.
    Also any tips for a first time buffing would be great. Have rubbing compound polishing compound spray wax and bottle wax. Thanks!
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,888
    66
    Re: question on Velcro backing.
    This article explains everything about backing plates:
    http://www.meguiarsonline.com/forums...ad-To-A-Buffer
    I personally always match backing plate/buffing pad combos and stay with the same manufacturer.
    Not all microfiber pads work well on rotary buffers. The machine is simply very powerful.
    If you don't have a previous experience with a rotary buffer, I would recommend that you practice this type of polishing first and get yourself familiar with this machine. Misuse can cause serious damage to your car paint.
    Dual action (D/A) polishers are safe and very user friendly. You can master your technique with this type of polisher very quickly and still be able to successfully remove most paint defects.
  1. Cut pad & Velcro backing separating
    By ebevo in forum Machines - The Dual Action Polisher
    Last Post: Oct 17th, 2008, 09:31 PM
  2. DA Velcro Backing Plate
    By toyotaowner in forum Customer Service Hotline
    Last Post: Jan 26th, 2006, 05:20 PM
  3. Need new velcro backing pad
    By Don in forum Detailing 101
    Last Post: Sep 25th, 2004, 01:29 AM
  4. 6'' Velcro backing plate
    By JG_Detailing in forum Detailing 101
    Last Post: Sep 17th, 2004, 11:10 AM
  5. Velcro backing pads
    Last Post: Jun 22nd, 2004, 05:25 PM
