Originally Posted by
First, to the original question: M21 Synthetic Sealant 2.0 vs Ultimate Wax - Both are 100% synthetic polymer sealants and both contain hydrophobic polymers. But they don't contain the same polymers so they aren't the same product just in different bottles. Ultimate uses our "thin film" technology which becomes immediately understandable the first time you use it - it goes on super thin and in liquid form it won't stain plastic trim. Ultimate liquid is the only wax/sealant we make that can either be allowed to dry for a bit before removal or wiped off right away with no change in performance. In some cases it actually works better if it's applied to a panel at a time and then wiped off before proceeding to the next panel. This is true especially on darker colors where a slightly heavy application can lead to an uneven appearance. M21 should be applied to all painted surfaces of the vehicle and allowed to dry fully before wipe off. Back to the polymers contained in these two products - M21 is very similar to NXT Tech Wax 2.0 in so much as they both use the same hydrophobic polymers but M21 has been slightly tweaked to better handle rotary application.
Second, to the discussion surrounding M20, cleaners, hybrids, etc. M20 Polymer Sealant would fall into that "hybrid" category where a blend of waxes and polymers is used but the emphasis is on the polymer side. This is as opposed to products that are generally considered to be "carnauba wax" like M26 Hi-Tech Yellow Wax, Gold Class Carnauba Plus, etc. These place most of the emphasis on the carnauba aspect, but since carnauba on its own is about as hard as a rock it must be mixed with other ingredients (usually various silicones, other types of polymers, etc) to make it usable. So you could argue that virtually any "carnauba" wax on the market is a hybrid of some sort. There is no such thing as a "100% carnauba wax" product in the sense that the bottle contains nothing but carnauba. Again, the contents of such a bottle would be hard as a rock. When a bottle or can states "100% carnauba wax" what it really means is that 100% of the wax in that container is carnauba - there is no montan wax, bees wax, paraffin wax, etc. It doesn't necessarily tell you what percentage of the container is actually wax, just that 100% of that portion is carnauba. So, back to M20 and M26 specifically - you could say that M20 is primarily a polymer with a bit of wax in it, while M26 is primarily a carnauba wax with some polymers in it.
Remember, too, that the word "polymer" is a very broad term. Wikipedia actually sums this up nicely with the following:
Finally, as to the cleaning ability of any of the above mentioned products, only M20 Polymer Sealant has any true cleaning ability here, none of the others mentioned in this discussion do. M21, NXT, Ultimate and Gold Class are all considered "polish waxes" since they all contain some level of polishing oils to help darken the paint and add additional gloss. M20 is considered a very mild cleaner wax, not even close to M06 Cleaner Wax, M66 Quick Detailer, D151 Paint Reconditioning Creme, ColorX or White Wax, but still a cleaner wax nonetheless. M26 and Deep Crystal Carnauba are considered "pure waxes" as they contain neither cleaners nor polish.
