Short work time with Meguiars Polish
Results 1 to 3 of 3
Thread: Short work time with Meguiars Polish
    Registered Member theamcguy's Avatar
    Aug 2005
    Fayetteville, NC
    65
    64
    14
    Ran into a problem today I had never run into before. Long time Meguiars user 40+ years. Was polishing paint temp 85 degrees inside the shop. I was getting maybe one to two passes on a 1 ft X 1ft area before the polish would dry out. I started with 105 figured OK try something else, then went to 205, same deal, finally ended up using Mirror Glaze #2 and getting it off with cleaner wax. I would do a 1 ft X 1 ft area, get 2 passes in and in the time it took me to put down the buffer and pick up a microfiber this stuff dried rock hard, it was like there was no oils in the polish. You could not work it so that you could do any cutting. You shoukd be able to get 5 passes on a 2 x 2 area but man this stuff was drying out way too fast. making it very difficult to remove. Is this common? I never remember having this problem before. Is there cure for it?
    Bill Strobel
    aka theamcguy
    Owner Independent Towing
    Fayetteville, NC
    Do It Right or Don't Do It At All.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    39
    5,357
    60
    Re: Short work time with Meguiars Polish
    Temperature and/or humidity could be the issue. M105 has a short work time to begin with. If you over work it then it dries like concrete and it's a pain to remove. You could use a spritz of water or QD to extend the working time.
    Sep 2005
    Sydney, Australia
    4,286
    63
    Could be the paint as well.
    Some older, neglected, dried out paints can also cause your polish / compound to dry out. Not sure if that was the case here or not...
  1. Meguiars M101 work time
    By juliom2 in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Oct 13th, 2013, 05:22 PM
  2. First time using DA/Work in progress
    By _Rodrigo in forum Show Off Your Latest Detail Work
    Last Post: Apr 22nd, 2011, 05:14 PM
  3. The Cure for M105's short working time and dusting issues
    By Lasthope05 in forum Detailing 101
    Last Post: Oct 19th, 2010, 02:20 PM
  4. How exactly does polish work?
    By pcmark in forum Detailing 101
    Last Post: Feb 23rd, 2008, 12:15 PM
  5. Why should I work in small areas at a time?
    By mike6789 in forum Machines - The Dual Action Polisher
    Last Post: Dec 1st, 2006, 04:32 PM
