The power of White Wax
Page 1 of 6 123456 LastLast
Results 1 to 10 of 56
Thread: The power of White Wax
    21,402
    1138
    There has been a bit of discussion recently regarding the effectiveness of White Wax so we wanted to share a recent project with you that demonstrates just how effective this product is when used as an all-in-one.
    What you see below is a couple close up frames of a single stage white Dodge Sprinter van. This thing is pretty huge, and the chalkiness of the SS white paint was so bad that you could run your hand over it and come away with a white powder all over your fingers. After washing and decontaminating the surface, we did three test spots on the hood, each with the idea that this was going to be a quick one step process. We used M20 and M66 first (opting out of even trying D151 since we were forced to work in full sun and D151 does not like those conditions). Why M20 and M66? They both worked very well on the WWII B25 bomber, Witchcraft, that we've done twice in the past - that aircraft had badly oxidized single stage paint and we were forced to work in direct sun. So, logical choices.
    But why put a consumer product, White Wax, up against these two? Simple: SMAT abrasives, and a fairly healthy load of them, are part of the formulation. Well, in our side by side by side test spots, White Wax was the clear winner, and so we proceeded to do the entire vehicle with it.
    A couple other caveats here: the buffer used was a Rupes LHR21 Bigfoot, not really for any additional cutting power it may offer beyond the G110v2, but because of its substantially larger footprint and the huge, flat panels that this Sprinter presented. We also stayed away from microfiber pads due to the heavy chalky nature of this paint, choosing instead to stay with foam polishing pads. We have very high confidence, however, that if you're working on any other paint than the rather unusual situation we had to deal with here, White Wax on a microfiber pad with the G110v2 would indeed produce outstanding results.
    We won't bore you with a bunch of similar looking pictures, but instead selected just a few to show off the true ability of White Wax. Below you can see a nice scuff mark in the paint, but also a general lack of gloss and clarity in the reflections. But look at the "after" shot below it: not only is the scuff gone (admittedly it took two passes to fully remove it) but look at the change in reflection and clarity! Lighting is identical for both images - they were take maybe 5 minutes apart in full sunshine.
    Here is a bit of a surprise, as we zoom in on the badge. All the gunk around the edges was taken care of with some all purpose cleaner and a brush, but the surface of the badge itself was simply passed over with the buffer, W8207 yellow foam polishing pad, and White Wax. And look at the difference!
    White Wax, a W8207 foam pad that has seen better days. It's all that paint residue that we wanted to avoid with microfiber pads as the microfiber would have wanted to hold on to so much of it and loaded up, very likely to the detriment of our process.
    This video clip shows the sort of transition we experienced every time we worked an area and wiped off the product residue. There was little to no reflection in the paint when we started, but after buffing a section we always got a kick out of watching a reflection appear as we wiped off the residue. Seriously, it just never got old!! Here we start filming on a section that has been buffed, we move to an adjacent area that has not been buffed and so is just as dull and flat as can be, and then we move back to the corrected section. Notice the reflections, even the palm trees in the background, as we go back to the corrected area. This with just a single pass of White Wax.
    Now, it must be stressed that this application of White Wax was not what you typically think of when applying wax. That typical wax application process, when done with a DA buffer, if most commonly accepted as being:
    • speed setting 3 on the DA buffer
    • a foam finishing pad
    • light downward pressure
    • very minimal product usage in order to spread it as thin as possible
    • fairly quick arm movements across the paint
    • each area covered in both a quick side to side and a quick up and down motion
    • larger areas covered at a time - perhaps as large as the entire hood of the car, or even half of one side, before adding more product
    • entire vehicle covered with wax, allowed to haze, then wiped off
    Again, the process outlined immediately above is typical for wax application via DA.
    But our process here was not typical for applying a wax. Oh no. Here, we treated White Wax almost as if it were a compound:
    • speed setting 5 on the DA buffer
    • a foam polishing pad
    • moderate to slightly heavy downward pressure
    • 3 large dollops of product for each 3' x 3' section covered (yes, we went a little bit larger than usual for heavy defect removal with a compound - but we were not chasing a show car shine here; it is, after all, a work truck!)
    • slow arm movements over the paint
    • each area covered in slow and repeated (3 or 4 times) side to side, then up and down motions
    • smaller areas covered with each section pass (as much as 3' x 3' as noted above)
    • product residue wiped off immediately following buffing of the section
    • pad was cleaned with a pad brush after every couple of sections
    White Wax performed beautifully on this project, even though we were forced to work in full sunshine on a pretty warm day. Thankfully the vehicle in question was white and not black, and we still highly recommend working in the shade on a cool surface.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    Re: The power of White Wax
    Thanks for the write up. This is exactly what I was looking for when using white wax.
    Sep 2005
    Sydney, Australia
    4,304
    65
    Amazing results!
    Those photos and video speak for themselves! That vid shows a dramatic difference.
    So do you think by wiping off the WW immediately after buffing you compromised its protection a little?
    21,402
    1138
    Not really, no. But if you're ever concerned about adding extra protection and you don't have a lot of time (this was, after all, intended to be a one step detail) then a good spray wax like UQW or D156 is a great follow up. The polymer protection in those two is surprisingly durable, and it's what we used on the WWII bomber both times.
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    After rereading this I had the same question Davey asked about any compromises in the durability of applying and removing white wax without letting it haze. Michael thanks for answering that and providing additional information on following up with either UWQ or D156. This is very helpful.
    Sep 2008
    Sydney, Australia
    1,352
    25
    Who's the handsome rooster on camera duties? WW really brought out their best side in the shiny paint reflections!
    Registered Member thegooseman's Avatar
    Mar 2010
    Glendale California
    33
    17
    The more I see you guys use this, the more I want to pick up a tube! For the abilities white wax has as an all in one product, is a good replacement for color x?
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    Yes it is. It offers more correction than colorx. Doesn't hurt to have it in your arsenal for those quick details.
    Aug 2010
    Fairmont, MN
    76
    1,441
    24
    One word: IMPRESSED!
    Thanx for the write-up (and further information) Mike.
    Bill
    Jan 2007
    Rochester Hills, Michigan
    613
    20
    This is what I went to when my boss asked me to wax his daughters car. Very well kept, but never before polished of waxed. I used my Craftsman 5" d/a variable speed sander, a green CCS polishing pad, and got to work. I was also in the sun that day. Again, Meguiar's comes through with the win.
    My Dad had a Dodge Charger. White. It has never been waxed, aside from some Quick Wax I applied back in 09. This will be my next test for White Wax.
    Also, my neighbor at work used it on his Caddy and loved it! He applied it with a rotary polisher, and finished with M26.
  1. White Wax and the DA Power System
    By cleanspotdetailing in forum Detailing 101
    Last Post: Mar 28th, 2014, 07:16 PM
  2. LC flat White pad and UC - enough cutting power?
    By Mossyoakglock in forum Detailing 101
    Last Post: Jul 12th, 2013, 07:25 AM
  3. Power hand polisher. "Power Pad"
    By Newport Viper in forum New Product Suggestions
    Last Post: Apr 9th, 2006, 08:23 PM
  4. the power of the clay bar in white paint (nissan platina)
    By The Doctor detailer in forum Show Off Your Latest Detail Work
    Last Post: Jan 4th, 2006, 10:51 AM
  5. Rotary Power-on Power-off
    By tripper_11 in forum Machines - The Rotary Polisher
    Last Post: Feb 4th, 2005, 12:09 PM
