How often do I need to use "Light Wax"
Results 1 to 10 of 14
Thread: How often do I need to use "Light Wax"
    Registered Member rytec's Avatar
    Aug 2013
    Flanders Belgium
    29
    7
    I have bought a few years ago some products from Meguiars and since I have used them, nothing else matters anymore, I will stick with it. But it's becoming an obsession http://www.meguiarsonline.com/forums...s/pullhair.gif Now when I wash my car every week with yellow wash&wax shampoo I also apply after that the light wax because on the package it says you can use this light wax between the washings. Is it necessary to apply this every time after a wash to keep the protection 100% ? Last time after the wash I applied NXT2.0 wax instead of the light wax. I also have a bottle of polish but I only apply that once a month and then on top of the polish I use the ultimate liquid wax. Thanks for some advise here
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,888
    66
    Re: How often do I need to use "Light Wax"
    The best way to go is: wax your car about 4 times per year (with a finishing wax, like NxT Tech Wax 2.0 or Ultimate Wax) and every time you wash your car spray a coat of spray wax (like Ultimate Quik Wax or Gold Class Premium Quik Wax) to boost the protection.
    Aug 2013
    Flanders Belgium
    29
    7
    Good morning, I have ordered a bottle of "Ultimate Quick Wax" together with a new washmit and a bottle of "Ultimate Protectant Dash & Trim Restorer" for my black plastic exterior and interior parts. After reading some posts, it should be better to use the UQW after washing the car instead of WW (because too often WW is not good for the clearcoat ?) and ULW everytime after washing the car will take too much time and costs a lot more then UQW ? Correct me if I'm wrong And like Michael Stoops says ; "Remember, this hobby is supposed to be your therapy, not the reason you need therapy."
    Nov 2009
    Brooklyn New York
    2,888
    66
    If you already have a fresh coat of wax on your paint (or two coats) applying more wax won't do much good for you. During wipe off most of it will be just removed as it won't stick to the paint surface. Therefore Meguiar's has maintenance products: quick detailers to remove light dust from car paint between washes and quick (spray) waxes to use after car wash (they can be used after each car wash or even after quick detailers). Using maintenance products will result in extension of this "just detailed" look of your car.
    Aug 2013
    Flanders Belgium
    29
    7
    How long should I wait to do a complete detailing again with UC, UP and ULW ? I mean, I have used last weeks WW on my car and last weekend after the wash I used NXT Wax on it. Would it be possible to do my complete detailing this weekend or won't it have effect because of aal the wax layers on the paint right now? And when to use the WW instead of the UC/UP/ULW ? the car is used every day.
    Nov 2009
    Brooklyn New York
    2,888
    66
    Every time you use a product containing abrasives (compound, cleaner polish, cleaner wax) you remove a layer of paint/ clear coat. That's the reason why Meguiar's always recommends to go with the least aggressive method as factory clear coat is very thin (and scratch sensitive). Full detail (with below surface defect removal) 1-2 times per year should be sufficient. Waxing every 2-3 months should provide good paint protection. Cleaner waxes, like White Wax, are great products to use when time does not allow for a multi-step detailing. When you have just small paint issues and no time for compound/polish/wax then all-in-one product can be used instead.
    Aug 2013
    Flanders Belgium
    29
    7
    Hello Greg,
    Thanks for clearing some points out for me, I'm digging it.
    One more question, does UP contains abrasives and take some layer away from the clear coat, I guess not?
    Or could I also do my Ultimate Polish with Ultimate Liquid Wax on top of it every 2 months?
    regards,
    Ryan
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,481
    63
    It sounds like you are doing this all by hand. Is that correct? If so I would not worry about you removing any clear coat. It will be so minimal especially doing it by hand. If it's by DA then that is a different story.
    On to your waxing. You should not need to wax every other week. White wax alone should last you about 2-3 months unless your in a sever environment where it may last a month. Once you have applied your coat of wax then you can use ultimate quik wax in between washes until it's time to wax again. Synthetics like NXT or UW will last longer than a carnauba based wax (white wax, black wax, A12, M6, Gold Class, M26, colorx etc..). Now you can top off a cleaner wax with something longer lasting to get you something that lasts a little longer.
    You can do this once or twice a year. If you don't have time then this is where a cleaner wax will come into play. I would leave your car as is for now and use UQW in between washes. Once your wax begins to reach it's end of life you can go over it with white wax again or a full correction. That is up to you and depends on how much time you have to invest. If you do a full correction UC or UP will strip off all the wax on the car now.
    Nov 2009
    Brooklyn New York
    2,888
    66
    Quote Originally Posted by rytec View Post
    Hi Ryan,
    Ultimate Polish is a cleaner polish, so it has mild abrasives.
    Pure polishes (no abrasives) are: Deep Crystal Polish DC2 and M07 Show Car Glaze. You can use them as often as you wish and because they contain rich polishes oils they can cover up any paint imperfections.
    Regardless of method of application (either hand or machine) when correcting below surface paint defects (scratches/swirls, water spots, oxidation) you need to remove a layer of paint/clear coat. If defects are deeper you need to remove more paint.
    Jul 2013
    Lawndale, CA
    40
    5,481
    63
    Quote Originally Posted by greg0303 View Post
    I'm in agreement with you. What I meant is more will be removed by machine than by hand unless he's hercules.
  1. Big "A" Detailing 2013 VW Golf R Tornado Red Light Polish & Wax with Lusso Oro
    By AndrewBigA in forum Show Off Your Latest Detail Work
    Last Post: Apr 19th, 2013, 04:09 PM
  2. Big "A" Detailing BMW 645 w-light swirls & holograms
    Last Post: Jan 20th, 2012, 09:13 AM
  3. does UQW "fill" light scratches?
    By fredcandetail in forum Meguiar's Consumer Line Products
    Last Post: Feb 19th, 2010, 07:06 AM
  4. Replies: 16
    Last Post: Aug 29th, 2008, 09:47 PM
  5. Where can I find a "Swirl Finder Light"
    By SkeeterJD in forum Detailing 101
    Last Post: Nov 6th, 2005, 07:34 AM
