yellowed vinyl / plastic window
Results 1 to 3 of 3
Thread: yellowed vinyl / plastic window
    Extreme Radiance Detailing gclark26's Avatar
    Oct 2013
    hutchinson ks
    222
    9
    Will plastx make yellowed vinyl / plastic convertible window new again?
    Are there any prep steps I should do behore applying plastx?
    2001 C5 Corvette - Black
    2010 LT2 Camaro - Victory Red
    39
    19,129
    237
    Re: yellowed vinyl / plastic window
    Well, as for the yellowing, maybe. Depends on if it is the surface, or all the way through. Can also try UC for a stronger cleaner...
    As for prep... you may need to apply some pressure, so if you can remove and work on a surface, or try to have something hard behind it, someone holding something, etc.
    Cadillac enthusiast Eldorado2k's Avatar
    Jan 2014
    Los Angeles, Ca
    41
    1,257
    20
    I tried M205 with a foam polishing pad on a Jeeps plastic windows and saw moderate improvment. From what I understand PlasticX is somewhat similar to M205[both being polish] yet much milder. I only did a quik run on the exterior and probably would've continued to see improvment if I had spent more time on it.
  1. Swirls on Plastic Trim next to window ...
    By FIREdawg in forum Detailing 101
    Last Post: Feb 7th, 2012, 08:16 AM
  2. Clear Plastic & Vinyl Window Wax
    By Michael Stoops in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: Jan 9th, 2012, 09:45 AM
  3. plastic window care
    By luckyinitaly in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: May 31st, 2009, 04:40 PM
  4. White Plastic Piece Yellowed
    By Stangfan in forum Detailing 101
    Last Post: Apr 17th, 2009, 11:36 AM
  5. PlastX on Convertible Plastic Rear Window
    By pwt65 in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Jun 25th, 2005, 09:11 PM
