Engine Cleaned
  • Engine Cleaned
    Hi I did not get photos of the engine when I detail the sliver car, the other week, so I took photos today. This is after running around in it. Light spray rinse engine with water, sprayed megs engine cleaner , let soak in , brushed around some bits I was able to easily get to, rinsed off lightly with water hose, turn engine on to slight warm, dry up bits of water spots, spray megs natural shine over , warm engine just a bit more, then left it, I notice it get better after each drive, I really like seeing it clean under the bonnet. [IMG][/IMG] [IMG][/IMG]
    Re: Engine Cleaned
      Re: Engine Cleaned
      [IMG][/IMG]
        Re: Engine Cleaned
        This photo bit is a bit off fun and games , soon I get it,
          Re: Engine Cleaned
          We're willing to bet this engine bay didn't look quite this good when the car was on the dealer lot!!
            Re: Engine Cleaned
            Not at all, dealers do have them clean sort of, with the methods learn from here and applying it sure is good, there is still I can get improvement, on the engines. same as each time when cleaning the cleaning the car exterior.
