Ultimate Black Plastic Restorer - Page 2
Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 74
Thread: Ultimate Black Plastic Restorer
  1. #11
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,393
    60
    Re: Ultimate Black Plastic Restorer
    Quote Originally Posted by zhackwyatt View Post
    Unfortunately on my car I have black plastic pieces (maybe 3/4 inch wide) that goes across the entire roof front-to-back. I don't see how I could use this spray w/o making a huge mess and/or wasting a lot of the product. I would have put some plastic sheeting and mask that down to protect a wider area.
    What about spraying to a cloth and wiping? Or is there a more durable form of Ultimate Black (non-aerosal) in the works?
    Have you tried cleaning the trim once in awhile with some APC and then applying ultimate black? I have found that ultimate black last a little longer when the surface is cleaned and prepped.
  2. #12
    21,401
    1137
    If that's the ONLY black plastic trim on your car, then this may not be the best choice for you. Even so, it certainly can be used on those pieces, but you're very best bet regarding application would be to mask off the area surrounding pretty thoroughly. You can pick up plastic sheeting in a roll that has masking tape pre-applied to an edge: roll it out, stick along the edge, then unfold the masking material and you're good to go. This is the sort of masking system 3M uses with their Paint Defender spray on clear bra and it works great. Unfolded, the masking plastic is usually about 3' wide, which should be more than sufficient for masking against overspray with this product. Application of the masking on both sides of the trim would probably take a couple minutes at most.
    We do not recommend spraying onto a cloth and then applying to the surface - it really needs to be spray delivered.
  3. #13
    Mar 2013
    Laguna Hills, CA
    7
    7
    There is no need for a final wipe down and in fact it is not recommended. Just wipe off overspray immediately and you're good to go.
    Thanks for the reply. My 2nd question didn't get answered though. Would this be safe for running boards? Sometimes products like this leave it somewhat slippery. Have you tried it out on running boards?
  4. #14
    Registered Member KBzPTGT's Avatar
    Sep 2005
    MD
    69
    14
    I have these long black rubber strips on my pearl white car roof also. I agree with this method and it works just as you say. The UB lotion lays down better and seems to last a little longer after a good APC cleaning.
    See Kevin's '03 PT Cruiser GT here: http://www.cardomain.com/ride/477590
  5. #15
    Nov 2014
    West Virginia
    5
    This product seems like it would also be great to use on hoses during an engine bay detail
  6. #16
    21,401
    1137
    Quote Originally Posted by AC in OC View Post
    No, it does not leave a slippery finish. In fact, it dries totally dry to the touch in a few minutes. No reason at all to not use it on running boards.
  7. #17
    Mar 2013
    Laguna Hills, CA
    7
    7
    Perfect. I will look for it when it becomes available. Thank you!
  8. #18
    Kinder Car Care Daniel Kinder's Avatar
    Dec 2006
    Paintsville Kentucky
    1,253
    32
    I think this will be a great product and will be waiting to pick up a can or two myself. Since I'm really interested in this product, I have a couple questions about the self leveling and the effect of drying to the touch coming from an aerosol and to hydrate weathered plastic back to new or like new appearance.
    1) Does it have Material Saturation Ability?
    2) Will it work equally well on colored plastic's?
    3) What Flavor or I mean what smell does it offer, if any since's it's coming from an aerosol?
    Thanks...
  9. #19
    Sep 2005
    Sydney, Australia
    4,288
    63
    This could just be the product I've been waiting for to spray on/walk away on grilles and other tight areas.
    I'm keen to read some reviews (Guz, I'm looking at you!)
  10. #20
    Jul 2013
    Lawndale, CA
    40
    5,393
    60
    You're calling me out huh . I'll be sure to write one since I am curious about this product as well. Especially in comparing it to D4510.
  1. Ultimate Black Plastic Restorer question
    By Vettefan in forum Detailing 101
    Last Post: Aug 7th, 2014, 11:51 AM
  2. Replies: 4
    Last Post: Mar 28th, 2012, 11:05 AM
  3. Ultimate Black Plastic Restorer vs. Ultimate Protectant
    By billoftt in forum Meguiar's Consumer Line Products
    Last Post: Jan 31st, 2012, 05:32 PM
  4. Ultimate Black Plastic Restorer
    By CWilliams4296 in forum Meguiar's Consumer Line Products
    Last Post: Mar 28th, 2011, 06:45 PM
  5. Headlight & Plastic Restorer
    By CHzo6 in forum Detailing 101
    Last Post: Mar 21st, 2011, 05:45 AM
