Ultimate Black Plastic Restorer
  • #61
    Just in case anyone's in need of removing this from their plastic trim, I called Megs cust. care hotline and Brendan suggested isopropyl alcohol.. That didn't work a lick.. So then I tried ethyl alcohol, that also didn't work.
    I finally found out what Will remove it from the trim, D108 and a Magic Eraser. D101 will work as well but the Super Degreaser seems to work alot faster.
    • #62
      Re: Ultimate Black Plastic Restorer
      I could have told you that IPA doesn't work on this LOL.
      Are you removing it from actual trim,paint or glass? I can see why the magic eraser would work as it is a bit abrasive.
      99 Grand Prix
      02 Camaro SS
      • #63
        I'm removing it from the actual trim [on the Tacoma] that I put it on a few months back. If you recall, I didn't have optimum results with it's application and I want to go back to using D4510 on that trim. IMO the D4510 is much darker and applies perfectly even. I'll have to re apply every 2-3 weeks, but I'm ok with it.
        • #64
          Gave it a shot on this grey engine cover to see what it would do on trim that is not black. It's overkill for the engine bay but I gave it a whirl.
          This is off my mom's 96 Regal.
          Cleaned it with D103 and the small Mothers detail brush.
          After applying ultimate black to it.
          One up close
          That Turned out Beautifully!
          • #65
            Thanks. You reminded me to check and see how it is holding up.
            The aerosol is great for some items.
            99 Grand Prix
            02 Camaro SS
            • #66
              Has anybody else had a problem with this product turning white after a few weeks? I applied to the trim and it looked great but after a few weeks the coating has turned chalky white in places and looks worse than the faded trim. I am hoping alcohol will remove it.
              Bill Strobel
              aka theamcguy
              Owner Independent Towing
              Fayetteville, NC
              Do It Right or Don't Do It At All.
              • #67
                Hi theamcguy,
                First, sorry to hear about your trouble. We would encourage you to contact our Solutions Hub at 800-347-5700 or customercare@meguiars.com. Our Surface Care Specialists can work with you to gather the details of your issue, and work to provide a remedy.
                • #68
                  Why isn't this fine product offered in a non-aerosol version ?
                  2014 Porsche 981 Boxster - Black Basalt Metallic; 21" wheels with oversized Toyo T1R racing tires.
                  • #69
                    They do offer it in a non-aerosol version
                    99 Grand Prix
                    02 Camaro SS
                    • #70
                      Thanks for that Guz...
                      Damn....Advanced Auto only had the aerosol version...which I just purchased.
                      • #71
                        Will any wax and grease remover work as well I wonder ? I noticed the big problem is the white staining with the body shop products.
                        The D108 looks promising : free rinsing formula prevents unsightly white residue stains
                        • #72
                          Guys - I applied the Ultimate Black Restorer but the results weren't that great....mainly because I could not CLEAN the plastic properly.
                          I used a garden-variety citrus cleaner. So the result was ....streaking....an uneven look.
                          What say ye to the best plastic cleaner: D101 ? (obsolete), D103 ? D108 ?
                          • #73
                            What was on it that needed cleaned off?
                            I always just use Meguiars All Purpose Cleaner for stuff like that first, maybe a terry cloth to work it in better.... but other brands are similar.
                            • #74
                              That's the "big problem"...I don't know what the heck was on there !! I'll bet some Armorall...tough to remove.
                              I think I should have used a medium scuff pad with the citrus...let it soak for 10 minutes, and then scrub.
                              Instead I used a piece of towel.
                              BTW: Thanks for that Murr....Go Steelers...I was born and raised there. Miss it for sure.
