NEW! Meguiar's Foam Buffing Discs - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: NEW! Meguiar's Foam Buffing Discs
  1. #21
    21,402
    1138
    Re: NEW! Meguiar
    Quote Originally Posted by sealthedeal View Post
    Could you specify how much cushioning one gets when using the 5 inch thin pad on a 5 inch BP? By 5 inch pads, do you mean the velcro area is 5inch and the foam pans out a bit or by 5 inch you mean the pad is meant for a 5inch BP ? Some of the shots (on Meguiars DA specifically) seem very close as if a slight tilt to the pad (or close to a curvy surface with downward pressure applied) may get the BP in contact with paint.. I am mainly interested with respect to the default 5" BP that comes with a GG6 (i am hoping its about the same dimensions as this new Meg 5" BP).
    I was hoping to see your scale measurements (of all sides) of these pads too (like you've done in other articles discussing pads).. Let me know if thats posted somewhere.. Thanks
    The foam discs are the same diameter as our microfiber discs, and the backing plate is the same diameter as the outgoing W67DA, which was the recommended plate with the microfiber discs. Overlap with the foam discs is the same as with the microfiber, so there is no fear of bringing the plate in contact with the paint by simply tipping onto an edge. The images below show all this in more detail.
    Diameter of backing plate: 4-7/8"
    Diameter of foam disc: 5-3/8"
    Total thickness of foam disc: 11/16"
    Backing plate mounted to pad showing slight edge of loop material and full width of foam disc.
    Disc overlap on a centered backing plate.
    Foam disc overlap with a centered backing plate: 9/32"
    Foam disc overlap with backing plate under maximum compression. This is smashed as flat as it will go, and something you would NEVER do when polishing paint.
    Foam disc overlap with backing plate at 45 degree angle and maximum pressure applied. Again, something you would NEVER do in real world buffing.
    The backing plate to foam disc engagement is not quite the "full width" coupling promoted so heavily by the likes of Kevin Brown in order to achieve maximum edge support and therefore maximum cutting and edge work. Just as with our microfiber discs, we felt that such a "full width" coupling, although offering maximum cut, would pose a very real risk of plate contact to paint that would be problematic for novice users. Rather than go that "full width" route we opted instead for minimal overlap that is enhanced by the scalloped undercut of the disc.
    The thin profile of these discs, paired with the lighter weight, gives them an extremely smooth user experience on traditional DA tools (they will transform the feel of a 7424, GG6 or G110v2) and gives tremendous cutting ability to the new burgundy foam cutting disc.
    Double check the exact diameter of your GG backing plate, but we know many have used that with our microfiber discs with no issues regarding plate to paint contact. It should be a non issue.
  2. #22
    Mar 2014
    PA
    7
    Re: NEW! Meguiar's Foam Buffing Discs
    Thanks for such a detailed reply Michael. Appreciate it !
  3. #23
    21,402
    1138
    Funny thing is.... as soon as I posted that I headed down to Jason Rose's office and what does he have sitting on the floor but a brand new Griot's Garage 6" buffer. Well, that thing ships with a backing plate that is 5-3/4" in diameter, meaning the factory stock plate with the GG6 tool is NOT suitable for use with our 5" foam discs. You must use our 6" foam discs with that backing plate. Our honest recommendation, however, is to go with our new 5" plate and 5" discs, for a couple of reasons:
    1 - the 5" size will give you greater cut, a smoother operation, and better control in smaller areas than the 6" will
    2 - the GG6 backing plate uses a very aggressive tall hook engagement, which is going to cause problems with the short loop found on our foam and microfiber discs. Their tall hook with our short loop is a serious mismatch that will produce a lot of heat at the pad/plate interface. A tall hook is not a great idea in general for a DA tool as the movement of any DA is such that it's always trying to throw the pad off the plate, and a tall hook/loop interface allows for too much lateral movement, which generates unwanted heat. Just an observation.
  4. #24
    Mar 2014
    PA
    7
    Thanks for checking that out. I actually have a DAS6PRO (from the UK side and I believe it has the same chasis as GG6) which additionally comes with a 5" BP (which is actually 4"7/8), so in my case that would work well with these new disks.
  5. #25
    Oct 2017
    Texas
    67
    3
    Hello to all
    i have a mint condition Meguiars G100 DA polisher along with a brand new, sealed W-64DA (5 inch diameter) backing plate. I just wanted to confirm if i can use the Meguiars buffing discs with the equipment i have. Pretty sure it should work but want to know for sure
    Regards,
    Mark
  6. #26
    21,402
    1138
    Quote Originally Posted by se9303 View Post
    Hello to all
    Regards,
    Mark
    Yes, Mark, our Thin Foam Discs and Microfiber Discs will work just fine with that tool and backing plate. In fact, they will actually act like an upgrade to that tool compared to the pad technology that existed when that tool was introduced.
  7. #27
    Oct 2017
    Texas
    67
    3
    Thank you Michael. I am looking forward to using the microfiber discs.
  8. #28
    Feb 2020
    London
    19
    Thank you, very helpful
  1. How to clean Meguiar's foam buffing pads
    Last Post: Jun 12th, 2019, 06:25 AM
  2. Meguiar's Soft Buff DA Foam Discs and Backing Plates
    Last Post: Nov 22nd, 2017, 09:51 PM
  3. New Toy - #5000 Grit Trizact Foam Finishing Discs
    By Mike Phillips in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Aug 31st, 2013, 01:15 AM
  4. Replies: 4
    Last Post: Sep 9th, 2011, 06:55 PM
  5. Damp-Sanding a 1956 Chevrolet Belair with Meguiar's Unigrit Foam Finishing Discs
    Last Post: May 24th, 2010, 05:06 AM
