Removing old wax / sealants question. Isopropyl alcohol yay or nay
  • Removing old wax / sealants question. Isopropyl alcohol yay or nay
    So after watching a couple of videos from autogeek, Mike Phillips recommended using 10% diluted isopropyl alcohol to remove polish after a swirl removal procedure.
    Also in another autogeek video (showing how to do a rinseless wash) https://www.youtube.com/watch?v=cICbdJocUI4 a couple of your guys at Meguiars mentioned using D114 to remove any prior waxes, so you have a clean base to start with. Whereas the D115 includes a little wax in the wash.
    Anyway this leads me to the question. Should we be removing any previous wax / sealant applications?
    I know Meguiars wax's says its ok to apply a new coat of wax over a previous wax. But maybe that just applies towards meguiars over meguiars... What about if the car was previously waxed or sealed with an other than Meguiars product ?
    Or is a clay and megiuars quik detailer (which may contain the same properties as D114?) sufficient enough to remove any previous wax / sealants ?
    Re: Removing old wax / sealants question. Isopropyl alcohol yay or nay
    If you are going to polish that will abrade the surface so that previous wax, sealant or coating will be removed. IPA is typically used to remove polishing oils after polishing. It's been mentioned on here that D114 at 6:1 can be used as an IPA replacement which in my opinion would be safer than IPA as D114 has more lubricity. It's a good way to check your work. At 6:1 it will strip off any wax.
    If you are staying within the same family say Meguiar's polishes and a Meguiar's wax/sealant then I would not worry to much about removing the polishing oils. As Mike Phillips would say it's about synergy staying within the same family.
    If you are going to clay or polish, it will abrade the surface and remove any wax, sealant or coating. As far as I know Quick Detailer and D114 do not contain any related properties. But I don't work for Meguiar's.
    99 Grand Prix
    02 Camaro SS
      Thanks, so would you all agree that 10% IPA is a good dilution ? D114 is $35, whereas IPA is a $1, (maybe even less if i have some in the cupboard lol) so leaning towards IPA for now.
        D114 is so worth the price to be honest. It's very versatile. I have used 15% IPA on a test hood but not on my actual car. It seemed to work just fine.
        99 Grand Prix
        02 Camaro SS
          Agreed. So versatile, and it is by far the best rinseless on the market.
          I've been using D114 with IPA mixed in with it. It allows for removal of polishing oils without being grabby like IPA is by itself.
          Also this thread is a great read on the topic of sealant and wax bonding:
          Miscible and Immiscible - Wax and Paint Sealant Bonding Sheldon explaining Quantum Physics to Penny on the Big Bang Theory Wax and Paint Sealant Bondi
            70% IPA off the shelf
            Buy a bottle of 70% isopropyl alcohol at your local grocery and simply mix it 50/50 with distilled water. Simple, economical.
