My thoughts on the MT300 and the new 5" pads
  • My thoughts on the MT300 and the new 5" pads
    Hi MOL,
    I picked up a new MT300 two weeks ago along with the 5" pads in Maroon (cutting), Yellow (polishing), and Black (Finishing). Today I used the new Da and some Yellow and Black pads. I did purchase the new backing plates in 5" and 3" size to use with the machine and pads.
    1st thoughts on the pads, thin, thin, thin. I have always liked and used Buff & Shine 5.5" flat pads as they were my favorite. I have to say these new pads are now my favorite. The control and balance you are able to have with them is superb. Being so thin, they do not deflect very much, and it is very easy to go right up to the edge of something and see exactly where the edge of the pad is. I used the yellow pad with my Rupes LHR 15ES and some 205 to put a nice finish on the hood of my 10 year old black Ford Focus ST. The hood has been repainted, the clear scratches very easily compared to the OEM paint, so I find myself needing to give it a little polish each spring. I know what you are thinking, why did I use the Rupes and not the MT300. I wanted to see how the pad did with the larger throw. I am pleased to say the pad did just fine, and easily removed all the light scractches and marring present in the soft clear coat. I was very, very careful in removing the pad from the Rupes backing plate, and would caution everyone to do the same when removing any non Rupes pad from one of their backing plates. The pad did not look any worse for wear from the larger throw.
    I then switched over to the MT300 with a new yellow pad and some Megs Black Wax. I used 4800 OPMS and some light pressure on all the painted surfaces. The machine was very smooth. It is not as smooth as the the Rupes, but much, much smoother than any other std DA I have used. I have removed the handle as my personal preference is to not use it. Thanks Megs for the little straight edge on the back of the polisher, enabling you to put it down without fear of the DA rolling over and possibly soiling your pad. The machine's torque management system worked as advertised. I had no issues keeping the pad spinning even on contours, just as long as you held it flat and applied even pressure. I used two pads for this car, but truth be told the 1st pad could have probably completed the entire car. It did not seem to saturate with product hardly at all. The yellow pad with the black wax left a very nice finish. The wax was a dream to wipe off. I did apply some serious pressure on a vertical panel to see what would happen. The machine handled it with little effort.
    I then threw on the black finishing pad and reached for some ULW. I knocked the speed down to 3800 OPMS and went to town. Effortless to put on. I put a coat on the entire car, and then removed. I don't
    usually have any problems with this method, even though Megs suggests you remove after a 3-5 minute period. This pad seems a hair firmer than most finishing pads, but it certainly did not mar any of the soft clear on the hood.
    The machine is very balanced, Meguiars isn't kidding when they said it is very ergonomic in your hand. It is quite easy to one hand the machine, even on vertical panels. I plan on using the machine tomorrow with the new 3" backing plate and one of the the 4" soft buff finishing pads to throw a coat of UPW over top. I am usually not a wax waster, but I am curious to see how the machine feels with a 3" plate and 4' pad.
    Next month I am planning on trying it out on my company car with the 5" MF discs (cutting and finishing) with D300 and D302. The car needs a decent clean up as it saw plenty of road debris and salt this past winter. I will report out after seeing how it tackles a little work.
    Final thoughts today on this DA is Megs has upped the ante for non large throw DA's. It is a very balanced machine that will not tire you out nearly as quickly as other short stroke DA's. It is a pleasure to use, and just feels good in your hand. The new pads (discs) are right to the front of the line. They seem to work well with large throw DA's as well as the MT300. I think if you arm yourself with the new pads and the Megs MF pads, you can tackle just about anything.
    Re: My thoughts on the MT300 and the new 5" pads
    Great review. I agree with everything you wrote. I usually use Lake Country flat or hydro tech pads and like you the new thin discs are my new favorites. Give the cutting disc a shot with some D300 on the MT300. I was impressed with this combo myself. It finished LSP ready for me. Even M101 finished LSP ready on the burgundy cutting disc. I agree with you that with these pads you can get right to the edge just like the microfiber pads. Speaking of microfiber, you will certainly like them on the MT300. I used the microfiber cutting disc on a couple areas and they worked awesome. The only pad I have not used is the finishing disc. I plan to use it on the next vehicle. One thing to note is how easily the new discs clean up.
    I also agree with you on the MT300. It's a great tool that's right were Meguiar's intended this tool to be. Paired with the new discs and that is all that is needed. My hands were less sore and I had less fatigue when using it. It also just spins the pad with the digital torque management. Meaning I had to use less pressure and let the machine do most of the work.
    Good to hear that they survived the Rupes.
    99 Grand Prix
    02 Camaro SS
      I'll have to try the Maroon pad with some D300. Thanks for the recommendation.
        Great review Kris! Def got me wanting one of those and some thin pads along with the mf pads. If u had a choice tho and had to pick one, would u go with a rupes or the mt? As nice as a rupes is it sounds like the mt prob b the way to go due to price and pad selection being the new thin and mf u could tackle anything and save some cash along the way.
          The Rupes is a great machine, but if I had to choose only one, I would go with the MT300 because of the versatility of being able to use multiple sizes of pads and backing plates.
            Thanks for the review Kris!
            Sounds like Megs is really onto a winner with the new discs.
            I hope they release the MT300 in a 220V version...
              I used the MT300 with the new Meguiars 3" backing plate and a Megs 4" Black finishing pad with some UPW today. The polisher is not as smooth with the smaller plate, I would expect this as they have mentioned several times the counter weight built into the machine was to balance the 5" plate and new discs. While a little more buzzy, still not bad, and I would say less tingle in your fingers than the competition's machines cause. Another winner from Meguiars!
                Thanks for the review, and we're thrilled that you like the new thin foam discs and the MT300 so much!!
                We often talk about how the MT300 fits into a multi tool operation, and where it might fall for those with a single tool mentality. In a multi tool approach, guys who love the cut of a tall stroke tool are often disappointed in that tool's difficulty when dealing with edge work or tight spots so they reach for a shorter stroke tool. But most shorter stroke tools can't hold a candle to the cut of the taller stroke tool so this operator sort of struggles through the lower cut when dealing with edge work. The MT300 is, we feel, the perfect compliment for a guy who is big on the multi tool approach since he gives up almost nothing in cut when dealing with edges, tighter contours, etc.
                In a single tool approach the MT300 is, we feel, pretty darn hard to beat. Great cut, gobs of torque, it can do edge work with ease and still speed through more severe defects on larger panels very quickly with the appropriate liquid and pad combo.
                It seems like you guys are picking up on both of these scenarios on your own, which just validates to use that our thinking with this tool was pretty much spot on. Thanks!!
                  Hey Mike whats the Warranty with the MT300 ?
                    Does anyone know where the new MT is manufactured?
                    2013 Toyota Tacoma TRD Offroad
                      I believe it's manufactured in China
                        Megs needs to make the new foam cutting discs in 4 inch size!!!!!! I love my MT300 and am glad I bought it.
                          What about cutting a larger pad to make it into a 4" pad? Just an idea.
                          99 Grand Prix
                          02 Camaro SS
