Why Hasn't Meguiar's Introduced a Paint Coating Product Yet?
Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: Why Hasn't Meguiar's Introduced a Paint Coating Product Yet?
    Feb 2010
    Bronx, NY
    12
    Are there plans to introduce a coating product soon?
    If not, what reservations does Meguiar's have introducing this new technology to its current inventory?
    It seems that all the other major detailing manufactures are introducing coatings as part of the new lineup as it's supposedly the latest and greatest detailing product to hit the market in years.
    I only ask, because whether it be detailing clay, polish, microfiber, or even a spray bottle, I always give the Meguiar's brand a chance due to its reputation in manufacturing high quality products.
    Registered Member DasBurninator's Avatar
    Nov 2014
    Denver, CO
    459
    Re: Why Hasn't Meguiar's Introduced a Paint Coating Product Yet?
    Meguiar's has had paint coatings in other markets for a few years actually. Just not in the US market.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,643
    66
    You will have to be like the rest of us and patiently wait until that day comes when or if that happens. I would rather they get the product right then to introduce something with lackluster performance.
    I waited as long as I could but I had to choose a coating when I did my dad's car. I would have gone with Meguiar's if there was one available.
    But yes there was a coating overseas.
    Registered Member Spazzz's Avatar
    Aug 2013
    Madison
    155
    9
    Meguiars Deep Crystal Coat kit M18802.......ebay 159.00
    Registered Member rqk's Avatar
    Jul 2006
    Chicago Illinois
    100
    16
    What is the difference between a wax (or even Meguiar's Paint Protect) and a coating?
    Jul 2013
    Lawndale, CA
    5,643
    66
    Quote Originally Posted by rqk View Post
    This should help you out.
    Coatings require more prep work but are supposed to be require less maintenance.
    http://www.autogeekonline.net/forum/...-coatings.html
    Quote Originally Posted by Mike.Phillips@Autogeek View Post
    3-Categories: Waxes, Paint Sealants and Coatings
    In an effort to help standardize terms used in the detailing industry, now that CQuartz and Opti-Coat 2.0 are mainstream, there are three general categories in the "Protection" category
    Waxes
    Paint Sealants
    Coatings
    Waxes
    Generally defined as any product that contains a natural or synthetic waxy ingredients that are intended to protect the paint and/or add beauty to the paint. These types traditional waxes will wear off under normal wear-n-tear, repeated washings and exposure to the environment.
    Paint Sealants
    Generally defined as any protection product that contains man-made or synthetic ingredients that are intended to protect the paint and/or add beauty to the paint. These traditional sealants will wear off under normal wear-n-tear, repeated washings and exposure to the environment.
    Coatings
    Generally defined as any paint protection product that contains man-made or synthetic protection ingredients that are intended to permanently bond to the paint to both provide a barrier-coating of protection as well as create a clear, high gloss finish. The products available in this category are considered permanent coatings because like your car's paint, they cannot be removed unless you purposefully remove them or you purposefully neglect them.
    Definition of permanent in the context of sealing paint
    This is kind of tricky just because the nature of discussion forums is for some personality types to read super literal into each and every single word, in this case the word permanent.
    In the context that we refer to coating as permanent it means that once the coating is properly applied and allowed to cure and set-up, it will not come off under normal circumstances or via normal wear-n-tear such as careful washing. So in this context, a coating is permanent in the same manner your car's paint is permanent.
    The paint on your car is not going to come off unless you abrade it, chemically dissolve it or in some other mechanical means, purposefully remove it. In this same way, legitimate paint coatings are not going to come off unless you abrade it, chemically dissolve it or on some other mechanical means, purposefully remove it.
    Traditional car waxes and paint sealants will wear off under normal use circumstances or via normal wear-n-tear such as careful washing. So in the context of and in comparison with traditional car waxes and paint sealants, paint coatings are permanent.
    Examples of Waxes and Paint Sealants can be found here,
    How To Choose The Right Wax or Paint Sealant for your Detailing Project
    Two new coatings now available at Autogeek.net are,
    Optimum Polymer Technologies
    Optimum Opti-Coat 2.0 Permanent Paint Coating
    CarPro Innovative Nano Coats
    CQuartz Ceramic Quartz Paint Protection 10 milliliters
    CQuartz Ceramic Quartz Paint Protection 30 milliliters
    Next Level Detail, LLC Clean'03's Avatar
    Dec 2014
    Phoenix, Arizona
    30
    7
    that would go against everything they do. preserve & protect, or correct a defect. It's like the detailer's out there who wrap their vans & trailers, what are you thinking!
    NXT Institute West Coast 'Class of 2015'
    Registered Member Top Gear's Avatar
    Feb 2013
    Carolinas
    842
    17
    My two opinionated cents: Coatings are not worth my time, give an inherently false sense of security, and I agree with Clean, they seem to go against the Meguiar's "Car Crazy" philosophy.
    I want my paint and its finish to breathe, particularly given weather swings. I want a deep dark wet look, not a shallow glossy plasti-dipped look. All things equal, the car is still going to get dirty and build up defects regardless of any coating, so it still has to be cleaned and corrected, and even coatings eventually wear/wash off, lots of money gone with them.
    Coatings are always oversold, too, and often sound like some tin foil hat conspiracy against waxes and wax companies. Yet, every time I see a truly great looking finish at a car show, I ask the owner about it. I've yet to hear anyone say they used a coating. They always say say it was a regular consumer wax/sealant you could buy from a store.
    First Correction | Gallery
    Jul 2013
    Lawndale, CA
    5,643
    66
    Quote Originally Posted by Clean'03 View Post
    Quote Originally Posted by Top Gear View Post
    I'm going to have to slightly disagree a bit. A coating preserves and protects. To me that fits in to the so called Meguiar's philosophy. It's the longest form of protection. Like everything else, coatings are not for everyone. The market for them is still growing. It may not be liked by everyone but coatings are becoming the future of paint protection. Enthusiast on a forum like this are a small number compared to the average consumer. A consumer hears long lasting protection with little maintenance and see's that as a huge benefit. Some coatings will even offer better scratch resistance. That is also seen as a plus.
    I heard this analogy from Renny Doyle. He's right on point. Take two popsicle sticks. Place one in a Dixie cup fixed with 30ml of any good coating. Take the other and place it in a Dixie cup of the same 30ml of a sealant or wax. Allow both to dry for three days. Pull the popsicle stick out of the cup of coating. You will have a Plexiglas lollipop. That's what's on your car. Pull the popsicle stick out of the sealant or wax. You'll have a smeared, messy popsicle stick. Which would you want protecting your paint? Its a great selling prop to show prospective clients.
    A coating is ideal for a daily driver. Also any swirls that will happen will be in the coating versus being in the paint. I must say after coating my dad's car, it's much easier to clean.
    For someone who enters car shows then a coating is not for them. Stick with a wax or sealant.
    Meguiar's made a huge leap with Paint Protect. That's as close to a coating as one can get. Hopefully this is the start of something that leads to an eventual coating. The market is ready for it.
    The ability to pick and choose the right combination that works for the individual is the beauty of being "car crazy".
    Feb 2010
    Bronx, NY
    12
    Quote Originally Posted by DasBurninator View Post
    Well then, what's the delay?
    Are there regulatory or safety reasons why they can't be marketed here in the US?
  1. Meguiar's M16 and M188 Deep Crystal Paint Coating [NEW]!
    By tapp1 in forum For Sale or Trade
    Last Post: Nov 20th, 2015, 11:30 AM
  2. about to apply a paint coating
    By gclark26 in forum Detailing 101
    Last Post: Jul 23rd, 2014, 04:41 AM
  3. 2014 nano-coating product MIA
    By jfelbab in forum The Break Room
    Last Post: Nov 6th, 2013, 06:34 AM
  4. Meguiar's Plastic and Vinyl Coating vs. Ultimate Protectant
    By Glen871 in forum Professional Line - Product Reviews
    Last Post: Dec 16th, 2011, 06:04 PM
  5. Never Introduced Myself...
    By tapp1 in forum Introduce Yourself - New Members
    Last Post: Aug 12th, 2009, 06:16 AM
